i think the seat belts are suppose to slide abck and forth when you open or close the door. mine do not move at all. is there a fuse or relay that controls this. i looked and couldnt find one for it.
what controls the auto seat belts in a ex?
ok josh to confirm, 9091 ex's came with auto belts.
i thought it was dx and lx 9091
i forget. sheesh so much dam info on our cb's hard to keep them all in my brain.**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7 View Postok josh to confirm, 9091 ex's came with auto belts.
The only 90/91 CB without auto belts was the 1991 wagon, which came with manual belts like the 92/93 CBs.
^^ cb masta**Blk Housed Slut Crew Member #1**
Originally posted by JoshM View PostIf it's a 1992 or 1993, the seat belts are controlled by your hand.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
theres a little box under the passenger seat that controls them...if you having problems with the seat belt still no working i believe theres is also a motor that is used to push and pull the seat belt on your door.
I was told that the motor in behind the plastic in the middle of the doors next to the seat that also goes bad.
I been meaning to fix my driver side one i switched 2 boxes thinking that was the problem but the driver side motor went bad so i would look into that.
also one of the guys up top is correct. only EX and SE models of 90-91 came with automatic seat belts all others dont have it
THis:
Originally posted by JoshM View PostALL (USDM at least) 1990-1991 sedan and coupe CB's came with auto belts: DX, LX, EX, and SE.
Originally posted by ErRrrLokiLlo View Postalso one of the guys up top is correct. only EX and SE models of 90-91 came with automatic seat belts all others dont have itOriginally posted by Shaar View PostMine is a 90 LX coupe, and it has auto seat belts, but they both don't work I was hoping to find some answers here! lol
Take it to the dealer. They're supposed to repair almost anything wrong with the motorized section of the restraint system under a lifetime warranty.
Originally posted by visualpoet View PostTake it to the dealer. They're supposed to repair almost anything wrong with the motorized section of the restraint system under a lifetime warranty.
On Topic: In the door, the part that locks onto the black latch on the door, not the door switch, is what actually sends the signal to the seatbelt modules to either retract or move forward. This is evident upon popping off the door panel and looking at the wiring in the 9091 and the 9293.
Visual Poet, I did not say anything incorrect. i was only replying to:
Originally posted by ErRrrLokiLloalso one of the guys up top is correct. only EX and SE models of 90-91 came with automatic seat belts all others dont have it
Originally posted by ShaarMine is a 90 LX coupe, and it has auto seat belts
