EXT: Power folding mirror JDM/USDM combo
    awesome thread almost jdm
      Originally posted by h22anow View Post
      here you go
      Why was this revised?
      I did mine with the original arrozburner diagram and I have no problems..
        so the relay box i assume sits in the D/S door somewhere? or did you run wires and tuck it under the dash? And for the P/S mirror did you have to run wires all the way across the car to it? or is it possible to tap into the P/S wires for a more cleaner look?
        member's ride thread
        91 Accord SE 176k
          Originally posted by wagonz View Post
          you cant switch the glass you gotta switch the body of the mirror. the jdm body curves in more so the view sucks but the usdm body is angled perfect. you need to switch out the guts and mirror glass. then youll see out them perfect BAM!!!!!!
          hm, that makes perfect sense thanks
            i have my relay box inside the driver side door panel, as far as the wires i ran them all the way to the other side under the dash and zipped tied them to other wires. the hard part for me was running them to the passenger door, thats where you have to get creative
              didnt work, the motor of the usdm mirror vs the jdm mirror is different, its hard to explain, but comparing them next to each other you can see that the usdm is longer, as far as "the body of the mirror" its the same except as stated above, where you have to make a new hole. anyways thanks for your help
                Everyone should note that this is for coupe. I have found that the number of mirrors made for 90-93 accords goes up from here. The PFM's that I have for sedan, did not have interchangeable guts/housings. The mounting stub locations for the motor inside the housing was different on mine. My objective here was to have the LHD (USDM) mounts with RHD (JDM) power folding option. The driver-side mirror was adjusted to the max and I can still see the whole side of the car covering half the mirror. The passenger-side mirror's adjustment was maxed out as well. I would have to put my head to the passenger seat before I could see the side of the car. Further investigation shows that the mirror actually had an angle specifically for LHD and RHD cars.
                I still had to paint the mirror housings, but not the base. From my experience, it appears that the sedan and coupe mounting base is different and there was no need for me to chizzle the little pin.
                Top: Sedan JDM power adjust/folding mirror
                Bottom Sedan USDM power adjust mirror
                My mounting base was different. I was able to swap my JDM base for my USDM base with no modification to the pin.
                You can kinda see the base in this picture. Just reference the holes and how they differ.
                I hope this helps some sedan guys. The down side is that you still have to paint the mirror housing, but you can do it with the USDM mounting base. I know there are some guys that were able to swap sedan guts.
                CB3 formerly hondaracer33
                  Ahhhhhhhh! I soooo gotta do this when I install my sedan mirrors ..
                  I gotta have Kyle take a look at this thread .. cuz I'm .. when it comes to this shizza
                  Nice wiring diagram too .. that should come in handy ..
                  Thanks you guys! Fawkin siiick write up!
                  Tomi
