#1 |
Wanna be JDM whore
excalibur02 : 1992 Accord EX (2)
1992 Accord EX 4 Door 5spd her name is Giselle. I bought this to replace my blue sedan Angela after she was rear ended. Please excuse these horrible pictures as they were from the Dealer. ![]() This is my 4th cb Sedan and is the 7th accord in the 8 I have owned. I plan on making this Sedan the best Sedan. Even better then my blue one. (please click the link to see) I bought this Accord in Virginia Beach. I live in North NJ. I drove down 8 hours just to see it and purchased it. Then drove back to NJ lol. Took about 22 hours total with frequent stops. Most of the parts on my old sedan will be transferred but I am doing everything slower and more detailed then ever. I will be updating this MR thread as much as I can. I will not be using my H22A or MP1A from my old sedan for this one. I plan on going more aggressive but give me some time. . . . EXTERIOR . . . JDM 92 93 1 piece headlight JDM 92 93 Front bumper and lip JDM 92 93 Foglights JDM 92 93 Foglight shroud Authentic G-Square Grille . . . INTERIOR . . . Stock Palmy Gray Gentex 177 Dual Display rear view mirror Converted the Defrost and Foglight button t3 bulbs to LEDs Driver side sunvisor with LED light for vanity mirror JDM CB palmy gray maplight with LEDs JDM CB NONSMOKER Personal Ashtray with red lining JDM CB Stainless Steel Door stills OEM cb9 Aerodeck cargo trunk floor OEM 98-02 Accord Rubber trunk tray . . . ENGINE . . . F22A6 . . . TRANSMISSION . . . Gearspeed rebuilt H2A5 Quaife LSD Differential ACT lightweight flywheel Exedy OEM clutch Corsport shifter cable bushings . . . SUSPENSION. . . Front Suspension D2 36 way adjustable coilovers 27mm front sway bar ES 27mm sway bar bushing and bracket ES sway bar end links ES bushings pressed into front lower control arms Ingalls -3° front upper adjustable camber ball joint Rear Suspension D2 36 way adjustable coilovers 22mm Progress rear sway bar OEM lower strut bushing Hardrace rear trailing arm bushing FatFour Customs FFC lower control arm Megan Racing lower toe arm Wicked Tuning upper control arm . . . BRAKES. . . Odyssey 5 lug Front Knuckles Prelude front VTEC calipers Brembo Powerslot Front Rotors Hawk HPS front pads Techna Fit 6 piece Stainless Steel brake lines . . . WHEELS / TIRES . . . 2nd gen Acura 3.2 CL wheels with Honda center caps 205/50 16 Federal Himalaya snow tires . . . AUDIO / ELECTRONICS . . . Stock . . . PARTS IN MY POSSESSION . . . Stay tuned . . . FUTURE PLANS . . . Lots of plans Like I said these are pictures the Dealer took. I apologize for the bad quality. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Comments / Opinions are welcomed ![]()
Instagram username MAURO02 If my pictures do not work and you see ****.com replace it with m1xe.com Last edited by excalibur02; 01-10-2015 at 12:54 PM. |
#2 |
Wanna be JDM whore
This is my first maintenance job on the new sedan ![]() OEM Honda clutch pedal cover. hehe My first modification to the sedan was the cb9 Aerodeck cargo trunk floor. Took about 2 hours to fit and made sure it was a clean install. ![]() ![]() ![]() ![]() Next mod was to convert the Defrost button bulb to orange LED and the foglight button bulb to green LED Then I made my next purchase which was the Gentex 177 Dual display rear view mirror. This is dual display so it shows Temperature and Compass. It also comes equipped with night time dimming so those bright HIDs or Halogens wont be blinding me anymore. ![]() Here I am mocking up the wiring to make sure it works. ![]() Got it mocked up and displaying both temp and compass. ![]() Here is the wiring harness I made. I use all OEM honda relay and plugs since there cleaner and slimmer then other automotive relays. ![]() Here is a picture of the display showing ICE when its super cold out. ![]() Now with the rear view mirror working and installed I cut up my headliner to fit the oem cb3 maplight. It matches the palmy gray interior unlike the CD5 gray which is darker. I also added the driverside light to the vanity mirror on the roof sunvisor. ![]() After driving from NJ to FL in April for vacation I noticed my axle was torn. ![]() I had replaced the axle and forgot to take a current picture lol As I like everything clean, I removed my seats to take out the carpet and clean the shit out of it. After cleaning it I power washed it to get all the grime off. Here is the before picture. ![]() ![]() Took this picture on Interstate 95 South in South Carolina back in April 2013. Right off the exit is a Honda Factory. hehe ![]() That sums of most of the mods and maintenance from this past Spring. Summer mods and maintenance is another post lol
Instagram username MAURO02 If my pictures do not work and you see ****.com replace it with m1xe.com Last edited by excalibur02; 11-07-2013 at 05:28 PM. |
#3 |
Wanna be JDM whore
During Spring 2013 I took out my Palmy Gray Dash. While I did this I installed my Viper alarm and extra sensors. I did all the wiring and soldered and heat shrinked all connections. After I was done with the wiring I installed my spare Black Dash. ![]() ![]() ![]() ![]() ![]() So all wires are not exposed and routed behind the dash. I was able to add extra sensors and wire in all options for the alarm. I also ran 2 extra wires to set up my JDM PFMs. Last edited by excalibur02; 11-11-2013 at 07:38 PM. |
#4 |
Wanna be JDM whore
Reserved 3
#5 |
Wanna be JDM whore
reserved 4
#6 |
Wanna be JDM whore
Reserved 5
#7 |
Wanna be JDM whore
Reserved 6
#8 |
Wanna be JDM whore
Reserved 7
#9 |
Wanna be JDM whore
Reserved 8
#10 |
Wanna be JDM whore
Reserved 9
#11 |
Wanna be JDM whore
Reserved 10.
Yeah I know its a bit much. But if you know how my last MR thread is you will understand... |
#12 |
congratulations on your new purchase post 1
#13 |
Congrats dude, rust-free clean slate is the way to go.
1990 Accord EX |
#14 |
Sad to hear about Angela.
#15 |
Damn that sucks about the Blue sedan bro but I have to say, that is a BEAUTIFUL sedan !
I've thought about buying a new clean CB like that but finding them is hard. Excited to see what's in store for this one. |
#16 |
Parts Masta
Ugly ass front end!
RETIRED...
#17 |
Thanks to Excalibur thats how I found my clean Sedan 92 EX
#18 |
Black Thunder
Maury strikes again.
Henry R Koni/Neuspeed 1992 Accord LX R.I.P 1993 Accord EX OG since 'o3 Legend FSM ![]() 'You see we human beings are not born with prejudices, always they are made for us, made by someone who wants something' -1943 US War Department video |
#19 |
Clean cb you got there and your on the right track! Can't wait to see how it comes along!
![]() ![]() MY MEMBERS RIDE THREAD FOR MY 92 ACCORD LX WAGON CURRENT ![]() MY MEMBERS RIDE THREAD FOR MY 92 ACCORD EX SEDANSOLD ![]() |
#20 |
You should make a DIY on that mirror set up, it's a nice upgrade
Thread Tools | |
