Old 09-03-2018, 08:25 PM   #1
F20BturboCB9
F20BturboCB9 is cool... so far.
Base Timing For Boost
Hi guys, first off I just want to say hello, as I am new here on the forums. Although I am new here, I have had my 92 CB9 for 8 years now and it has been a pretty long journey, which leads me to my question. Right now I have an F20B in it, it is turbo'd and ran by an S300. My question is, do I have to take timing away from the base timing and sync it to the S300 or do I set it to what the factory spec is, which I think is like 18 degrees and then sync it to the S300 and just take the -0.75 to -1.25 per lb of boost off the map? Thanks in advance for any replies and I will try to post up some stuff on it in the beginners picture section once I figure out how to add pictures.
F20BturboCB9 is offline   Reply With Quote
Old 09-04-2018, 12:49 AM   #2
jamin_jacob
jamin_jacob is cool... so far.
it should not matter as long as you double check the timing with a timing light before you sync it
No marathon gets easier later. ...
jamin_jacob is offline   Reply With Quote
Old 09-04-2018, 05:59 PM   #3
F20BturboCB9
Basically I went to the set timing feature in the sManager, put 13 in the box, and then set the distributor to 13 with the timing light and then confirmed it back in the sManager. I have actually been driving it for awhile now and it seems to run great. In all of the datalogs I have never seen it knock. AFR's and EGT's look great also. I guess I just wanted some reassurance, lol. Thank you very much for your reply.
boost , f20b , s300 , timing
