Glad to hear you are ok man. Sucks about the teg, hopefully you can fix her up and get her back on the road.
Tippey764 : 1991 Integra RS
Ugh i just put in 5 hours to get the sub frame off. Luckly EVERYTHING went smoothly. I only had 1 small problem getting the steering rack out at the end, the joint was not released enough to let it slide out. Besides that i didn't have a single stubborn bolt, stuck clip or random bullshit problem, even the bitch pin on the shifter assembly came out with ease.
The damage
Originally posted by dhill_cb7 View PostHow much did that run you?
Pick and pull?
I got this from him
Front lower sub frame
Front left lower control arm
steering rack
front sway bar
windshield wiper cowl
1 front mud flap
shift rod in better condition than my own
All for $60. he was an 80 mile drive ( 160 round trip ) but it was worth it.
Originally posted by Tippey764 View PostWhats wrong with yours?
I wanted to see if they over looked anything so i took off the plastic cover that protects the front subframe. I noticed that it looked somewhat damaged. I was at a pick and pull trying to get the subframe but the bolts were stripped so i just took the toe bar i believe(piece that hooks up with the flexpipe hanger).
Well the holes don't line up mine are off by a 1/2 inch. So i'm stuck between a rock and a hard place at this point because as of right now had two alignments since then. They have said it is 2 degress off or something? So now it is eating away at the inner portion of my tires.
I figured i would try and replace anything that i noticed was damaged but i think it is leading me to believe the frame may have been damaged....and it maybe ireversible...
Well after an ass load of work and money the car is back together and driveable for the most part
Parts i had to buy
2 new lower ball joints
2 new tie rods
2 new axles
a new wheel ( i just bought a new set of wheels )
A new left lower control arm
A new left knuckle
Exhaust gaskets
All in all i think i've spent about $600 on this car for this accident. fuuuuuu
Is this the first legend you've had? I know youve always liked them
C-3PO's MRT USDM yo!
Nice teggy. I love the DA coupes
BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
