When you took the washer type thing on the crank that keeps the belt in place, you probably didn't put it back on correctly. It's concaved to hold the belt on, but if put on backwards it can rip the belt to shreds. Thats what it sounds like to me.
timing belt issue
Originally posted by mayberry View PostWhen you took the washer type thing on the crank that keeps the belt in place, you probably didn't put it back on correctly. It's concaved to hold the belt on, but if put on backwards it can rip the belt to shreds. Thats what it sounds like to me.____
What "washer type thing?" are you talking about--I don't remember one on my car and you're making me worried as I recently redid my t.b. though the belt has not shredded so far.
From the outside in, there's a the big crankshaft pulley bolt and key, then a thick washer, then the timing belt pulley, then the balance shafts pulley, then the crankshaft is bare as I remember it. I don't remember any "concave washer thing". There's a lip on the crankshaft pulley on one side of it, which I placed so it was on the inside--so you can slide the timing belt on and off the pulley--but that's the only way you can install it and still see the markings on the pulley. Is that what you're talking about?
Clarification is eagerly appreciated!~Last edited by batever; 05-28-2009, 10:20 AM.
There are belt guides the go infront and behind the crank pully. One stays on because you have to pull the crank pully off to get to it. The other comes off before the timing belt. If they are not on the belt could possibly move around. If both are off then the crank pully is probably out of alignment and thus would cauce belt wear. For it to shread there has to be contact somewhere. It could have been over tightened but there would have been noise from the cams etc. I would be worried about bent valves at this point. Good luck.
Originally posted by low-keyseg92 View PostThere are belt guides the go infront and behind the crank pully. One stays on because you have to pull the crank pully off to get to it. The other comes off before the timing belt. If they are not on the belt could possibly move around. If both are off then the crank pully is probably out of alignment and thus would cauce belt wear. For it to shread there has to be contact somewhere. It could have been over tightened but there would have been noise from the cams etc. I would be worried about bent valves at this point. Good luck.
Im guessing there are no guides then on the crank pully for the F series motor. I have never seen a guide on the tensioner of a Honda car but that dont mean there is not one. If you think that could be the problem then look in the manual and see if it is installed properly. Either way the belt was able to move around enough to get cut/worn.Ill check my manual when I get home in the morning, I cant picture it now.
