Engine
-JDM H22a
-prothane dog bone mount
-skunk 2 pro intake manifold
-AEM adjustable fuel pressure regulator
-AEM fuel rail
-solid motor and tranny mounts
-usdm H22 dizzy
-Koyo aluminum radiator
-battery moved to the trunk
-F22 front water neck with sensor
-F22 engine harness
-chipped P28
-Mishimoto fan
-iac delete
-fitv delete
-XTD stage 3 6 puck clutch
Wheels / tires / suspension
-17" Motegi wheels
-sprint performance springs
-front upper strut bar
-front camber kit
-4th get lude rear hubs
-4th gen lude front knuckles, hubs, caipers, lower all joint
Exterior
-DIY black housing headlights
-DIY Infiniti projector retrofit
-DIY mesh grill
-oem fogs
-CF exhaust trim
-CF gas door
-GM pewter paint code 382e alt #5
-amber corner lights
-oem bmw side markers
Brakes
-Hawk brake pads front and rear
-4th gen lude brembo blank rotors front and rear
Interior
-bb6 dash conversion (black suede)
-bb6 cluster
-bb6 seats
-bb6 center console with tunnel and ebrake
-dual gauge pillar pod molded onto a pillar and painted grey
-auto meter voltage gauge
-auto meter oil pressure gauge
-97 accord map light
-weighted shift knob
-NRG steering wheel
-NRG quick release hub
-white led's courtesy light under dash
-black suede door inserts
Future plans
-NRG engine damper
-Sti brakes front and rear
-black suede headliner
-black suede on the rear deck
-black suede door panel inserts
-at least a partial wire tuck
-abs delete
-srs delete
In progress
-Full system
I'll post updated photos as I get them. I have alot of work ahead of me.
