Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner "Off Topic"
Old 02-15-2020, 06:36 AM   #1
SedanTom
SedanTom is cool... so far.
Turbos and Camshafts! Video show and tell!
Wanted to share this video with you guys that I just watched. Gives great insight about your camshaft choice for your engine if you are turbocharged. They are talking about LS engines mainly, but I guarantee the same logic applies to our four-bangers. Hope it's helpful for you guys thinking about going turbo!
https://youtu.be/SzXjw3Png3E
SedanTom is offline   Reply With Quote
Old 02-15-2020, 02:35 PM   #2
Raf99
I mean i'm half way through this thinking "ahh ya, no duh". This guy is just saying the curve of your graph will be the same no matter what parts you throw at it. But i thought that was common sense.
Old 02-15-2020, 06:08 PM   #3
SedanTom
You're just too smart for me It never really clicked with me, he just made it easy to understand. So much misinformation around these days it all just gets jumbled around in my head. Cause I've always thought to myself, well if ever I wanted to build an N/A engine first then I'll HAVE to change the cam if I ever went to a turbo setup to make it work well. When I wouldn't have to until I wanted to change how the turbo responds really. If I can help out just one person with something I share then that's all I care about.
Old 02-15-2020, 06:24 PM   #4
sonikaccord
I stopped early. It looks like he's going to have some convincing information tho.
Boost doesn't do anything special to the air going in the engine and by special, I mean it doesn't make it flow faster or increase the CFM by itself. But you are right, there is a metric ton of half-right to just plain wrong information out there, especially about how an engine breathes.
God that LS power tho....
YouTube Clicky!!
Old 02-17-2020, 03:57 AM   #5
SedanTom
I know right! such capable engines, makes sense why everyone uses them especially combined with their form factor. I should have just said to watch the last 3 min or so, would have been easier, he asks the questions you might want to ask yourself, hypothetically, if you were to build a turbo'd engine.
Old 02-17-2020, 11:01 AM   #6
Raf99
But also a good point everyone including myself overlooks. If you have shitty setup to begin with you'll get fast shitty when you slap a turbo on. Which in the end affects your numbers. And it takes an experienced person to know what works. IE: At what point do you move to a 44mm WG vs a 38mm on a H series. Or the debatable 2.5" exhaust vs 3" exhaust. No point in using a GT35R turbo if you only want 300HP.
Old 02-17-2020, 07:11 PM   #7
SedanTom
See, I wouldn't even know where to start with Wastegate size and things like that (I'd probably ask the company I got the turbo from realistically or ask the forum). But couldn't have said it better myself Raf! Thanks for the input guys.
cam , camshaft , richard holdener , turbo
