Hey need some good positive info on putting nitrous on my car... I've been thinking about putting a 50 shot on my car... I have a 94 Accord with H22 with my F22 trans (tempo til I'm about to get a H22 trans)... I have a AEM cold air filter nd full exhaust (eBay)... other than that... Bone Stock... will I run into major problems if I put a 50 shot on my car??? Im not planning on spraying my car everytime I drive or even wen I get out there nd race... just every now nd then type thing
Stock H22a1 on Nitrous
Originally posted by Corweena View PostDefinitely not worth it. I would at least want to replace all of the seals in the engine before doing Nitrous.....because those will most likely be the first thing to go from the added power/pressure.
My co worker's dad had nitrous on his Harley and melted a hole the size of a half dollar right through one of his pistons.
C-3PO's MRT USDM yo!
A 50 shot is generally safe, though replacing the seals is a VERY good idea. Do a compression test to ensure each cylinder is healthy.
Used sparingly, with a healthy engine, clean injectors, the proper spark plugs, and a quality NEW nitrous kid (ZEX is the brand I would go with, personally), a 50 shot isn't likely to do any serious harm. If you run through a bottle a week, things will break. If you just spray once in a while... at the track, or impressing your buddies on an empty highway (not that I condone nitrous use on public roads), then it's unlikely that it will break anything anytime soon.
Go higher than 50, and you'll be pushing it.
For such a small shot, I suggest a Zex dry kit. A single point wet kit will be more likely to result in an uneven distribution of nitrous, which will cause one cylinder to run very rich, while the other runs very lean.
Most nitrous problems stem from wrong fuel/timing and lean conditions. I used to have a 92 sentra with a ga16de and sprayed it 150hp shot quite regularly. The biggest killer is not the amount but how progressively it comes on and proper tuning. I always ran a little more fuel than was needed and had the nozzle about 8-10" away from the throttle body and kept 1ş timing for ever 50hp. I usually use one step colder plugs and got my best results on 950psi. I think the zex kit with the built in purge is the best kit out.
Originally posted by jdm92_accorn View PostMost nitrous problems stem from wrong fuel/timing and lean conditions. I used to have a 92 sentra with a ga16de and sprayed it 150hp shot quite regularly. The biggest killer is not the amount but how progressively it comes on and proper tuning. I always ran a little more fuel than was needed and had the nozzle about 8-10" away from the throttle body and kept 1ş timing for ever 50hp. I usually use one step colder plugs and got my best results on 950psi. I think the zex kit with the built in purge is the best kit out.
I think the most important part about running nitrous is how it is delivered. Generally speaking, I think nitrous is safe to run but should be limited to track cars.
My thoughts.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Originally posted by H22_CBR View PostThx for all the good feedback... as far as ignition goes will MSD be perfect
Ignition upgrades are pretty much worthless on anything but a major build. Don't waste your money.
Also, the Zex kit essentially removes the need for tuning when dealing with a 50 shot. The little "brain box" that it has is essentially a piggyback controller. I believe it will adjust fuel accordingly. Installed and used correctly, a 50 shot Zex kit is very unlikely to do damage.
I do agree about using it on the track, however. Nitrous isn't much good for the street. If you want to boost power for the street, put some forged pistons in your engine and pick up a turbo kit.
Originally posted by deevergote View PostIgnition upgrades are pretty much worthless on anything but a major build. Don't waste your money.
Originally posted by H22_CBR View PostOK as for a turbo system Wats a good system to run??? Not looking far major boost right now... just want something like a starter kit til I'm able to do tha bigger upgrades like get the head components upgraded, head studs, the crank, etc....
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
