Hi, just arrived from the store and what i see? white smoke comming from my hood, just a little bit, so I was in the driveway and i opened the hood, looks like the radiator is leaking but just a bit. by the time i check where it came from, on the floor there's already a small spot of prestone. The leak is from the radiator but How the hell could this appen so.. what should I do? buy an additive for prestone leak and see what it does and if the leak is still there then i should replace the radiator?
Prestone leak
where is it leaking from???
is it seeping from the top seal of the radiator? is it leaking from those hoes where they meet the radiator?
sometimes it can be simple, unless the radiator is done.
nothign lasts forever, sometimes running low on coolant heats up the radiator seals and then it dries up and busts.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
it's leaking from the radiator "grill"
picture here
i cant get a clear picture but looks like it's leaking from the red circle ( and maybe the small one too... not sure about this one ).
picture here
Ill try the additive this after noon. The additive is Formula 1 Cooling system Leak Stopper.
i say just replace the radiator, you can get one from autozone for $103.
i was coming out of a walmart when i saw i had a coolant leaking out of my radiator, i was driving to tacobell for dinner with a buddy the previous night and he said he smelled something sweet and that it had the scent of coolant.
sure enough i had a cracked radiator near the lower hose.
on a side note, did anyone else notice that Honda's antifreeze is now blue? on the bottle it says Type 2.
dude that pic is actually ur AC condenser in front of your radiator. your radiator is sitting right behind it and probably has a pin size hole leaking onto your condenser, you can get some sealant that you put into your radiator to help it stop but i doubt those work 100%.
get a new radiator cause its very easy to change, might as well change the hoses and the thermostat while your at it.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Cool thanks for tip :P yeah ill go to the garage tomorow but i dont know if i should do it myself, i mean it's not a problem to remove it and replace it, i just dont want to mess around with the prestone ( air bubble in the motor or thing like this ), except for that, i can do it myself.. I think ill use the service manual to flush and fill the new prestone in. Ill give you news. Thanks again !!
By the way.. 2 days no cb7 = OMG
2) The leak is comming from the other side of the cap. on picture the prestone leaked for a good 20 mins so there's prestone everywhere.Last edited by Jetro; 07-07-2006, 02:14 AM.
it is really fun and easy to change the radiator.
get some pails for the fluid and drain it with that white plastic cap under the radiator, then take off the hoses or cut them off if u are replacing them. take off the top things holding the radiator in place, disconnect the fans and then pop it up.
if you have an auto you have to disconnect the lines down there.
takes about 40 minutes taking your time.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
hahah it wont come out. it just drops in thereWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Done , just replaced my radiator, well pretty easy.. i had a small oil leak but fixed, and small leak from the hose but also fixed, now brand new radiator for 120$ it was someting like 45 to 110$ for the installation ( canadian$ ). Just a question, should i flush all the prestone and refill it with new ? cuz now i just flushed the radiator, remove it, replace it and refill, i didnt touch the motor .. what should i do?
fill it with 50/50 water and anti freze. then open the little valve on the thermostat (10mm) and let the car run with the climate temp to hot. u will see bubbles, when u stop seeing it then your done.
...you didnt change the hoses or thermostat?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
i changed only the radiator, i didnt touched the motor base and no i didnt changed the hose. In the manual it says for automatic 2.2l i need 7.1 l. of prestone, but i removed only like 4 litter from the radiator, and nothing from the motor...
EDIT:
I have a lot of problem with the heating switch, this winter i had difficulties to turn it from cold to hot, and now it's almost free.. but when i turn the fan ON the air is hot. could my heater valve ( picture here ) could be the problem? or the cable itself?Last edited by Jetro; 07-10-2006, 04:14 PM.
