My A/C starts off cold then warms up... then gets cold again for a little bit. I really dont know whats going on...any ideas?
A/c
I suspect it is starting to get low on gas, which can cause that issue.
My 5.7 LS1 Holden Ute
Id guess your getting low on refrigerant, and it could be leaking out. Your high or low pressure sensor is not seeing the pressures it wants (lack of refrigerant) so its shutting off the compressor (safe mode) and not generating cold air. And its doing it intermitantly so its on, off, on, off and so forth... If you have access to an a/c recharge system (or take it to a shop) have the refrigerant pulled out, note how much comes out (should be 32-34 oz i beleive). If its not, recharge it with the proper amount and put an a/c dye (leak finder) in it so when your having these problems again you can use a black light and find the source of the leak (thats only assuming you have a leak and your refrigerant isnt just low from evaperation, inproper charge, etc).
_____________________________________________
2 year ASE Certification/Auto Technician Degree completed
Originally posted by eazyduzit509 View PostId guess your getting low on refrigerant, and it could be leaking out. Your high or low pressure sensor is not seeing the pressures it wants (lack of refrigerant) so its shutting off the compressor (safe mode) and not generating cold air. And its doing it intermitantly so its on, off, on, off and so forth... If you have access to an a/c recharge system (or take it to a shop) have the refrigerant pulled out, note how much comes out (should be 32-34 oz i beleive). If its not, recharge it with the proper amount and put an a/c dye (leak finder) in it so when your having these problems again you can use a black light and find the source of the leak (thats only assuming you have a leak and your refrigerant isnt just low from evaperation, inproper charge, etc).
Originally posted by Tippey764 View PostYour not low on refrigerant lol. His a/c blows cold as fuck. Then as he starts driving it feels like it justs turns off. When you click the a/c button you dont feel the compressor kick in anymore.
