Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 07-27-2011, 11:50 PM   #101
nate'sCB7
nate'sCB7 is cool... so far.
Originally Posted by JaberCB7 View Post
I believe their the same design (mechanically) but the V6 might have a slightly bigger rotor and caliper. If you want better performance Ive heard of members using the Acura Legend calipers witch uses dual pistons
True, correct me if im wrong though.
But because the Legend calipers are a rear mount style (cb7 calipers are on the front of rotor)
with the dual pistons, the larger of the 2 would be on the bottom which doesnt allow full contact of the top piston.
Unless you can mount them on the opposite side, of a CB. Hopefully that made sense....
nate'sCB7 is offline   Reply With Quote
Old 07-31-2011, 07:53 AM   #102
speedfr3ak
speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire. speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire. speedfr3ak Needs to slide down a razorblade into a pool of alcohol, and then be set on fire.
yea it does but it mounts in same place calipers is just bigger best to use 95 legend g,s brake setup they have bigggggger calipers and rotors
This thread is over a year old, you fucking retard.
i dont know why this popped up but U MAD BRO? not my fault u is FAKE! CLOWN ASS
speedfr3ak is offline   Reply With Quote
Old 08-02-2011, 05:04 PM   #103
pupildel
Accord of the Month - February 2014
pupildel is cool... so far.
Send a message via AIM to pupildel
Question
so i have 93 accord LX ok so pretty much all i need for the rear drum is a prelude hub and crv drum to do a 5 lug drum conversion right.....so would that set up of the front work too cuz i see you have 6 gen accord so you jus wondering if the front set up will work
pupildel is offline   Reply With Quote
Old 08-02-2011, 06:18 PM   #104
gloryaccordy
I think that's what people do (flip from left to right)
I really don't think all that trouble is worth it though
My friend had a 2002 Altima 3.5 SE which weighs like 300-400lbs more than a CB... all he did was upgrade the rotors + pads, and that thing stopped on a dime from like 120MPH back to back to back
Prelude caliper/rotors are the same size up front... u get Brembo blanks + nice pads... u don't need much... and u dont have to worry about calipers.
Old 08-03-2011, 12:10 PM   #105
P5ylance
P5ylance is someone to admire P5ylance is someone to admire P5ylance is someone to admire
you can mount the legend caliper with the bleeder valve down and how its supposed to mount (but on our cars), and when it comes time to bleed it, all you need to do is remove the lower bolt holding the stuff in, loosen the top bolt, swing it up, stick a spare rotor or something solid in there to act as a rotor, and bleed normally.
mounting bleeder up will make it convenient, but it won't take advantage of the different sized pistons, IIRC.
P5ylance is offline   Reply With Quote
Old 08-09-2011, 10:10 AM   #106
Gtseviper
Gtseviper is cool... so far.
Have you ever thought about trying these after your 5 lug conversion
http://www.6thgenaccord.com/forums/s...ad.php?t=33225
tsx retrofit
f22b dohc boosted
custom gauges pods
Gtseviper is offline   Reply With Quote
Old 08-10-2011, 02:43 PM   #107
nate'sCB7
For the sake of keeping this swap a direct bolt on mod,
Does anyone Actually know if the '00 V6 calipers provide the same performance as Vtec calipers.
If thats the case then this swap is a double win, you go 5 lug and get a brake upgrade.
Old 08-24-2011, 09:55 AM   #108
freaky
freaky is cool... so far.
is there any other honda knuckles that have s5 stamped on them.
freaky is offline   Reply With Quote
Old 06-14-2012, 01:42 PM   #109
drummersteve7
Boost Junkie Rehab!
drummersteve7 seems to have made some friends!
I am dropping another question.
Who has used extended studs on these?
If you check autozone it says the fronts are bigger than the rear studs.
Thread Pitch is same 12x1.5 but the stud shoulder seems bigger.
I am looking to do my fronts as well, anyone know where I can get some extended studs to finish my wagon?
and able to answer my own question, figured I would post in here for those that try.
Knurl is 12.35 on front and 12.25 on rear.
just remember that, so when ordering your extended studs just make sure your lengths are the same.
have a pleasant day, compliments of Cici from Ichiba.
MadLab Racing
Southern Maryland
drummersteve7 is offline   Reply With Quote
Old 11-06-2013, 05:13 PM   #110
bobbycos
bobbycos seems to have made some friends! bobbycos seems to have made some friends!
Send a message via AIM to bobbycos
bumping an old thread for a member who couldn't find it
bobbycos is offline   Reply With Quote
Old 11-29-2013, 07:47 PM   #111
F20A CB7
Bump for info. If u have abs, and do this swap, do u have to bleed the abs system first?
Some ppl say yes some say just bleed the brakes only.
Old 11-29-2013, 08:22 PM   #112
bobbycos
bump for info
, i was gonna answer this but ABS is not my thing
Old 04-16-2014, 05:41 PM   #113
8ball
8ball seems to have made some friends! 8ball seems to have made some friends!
Originally Posted by bobbycos View Post
the rear is basically 16 parts involved
2 prelude rear hubs
2 crv rear drums
2 5 lug rims of your choice
10 lug nuts
that is all
as for the front use 2000 up to be safe
Im guessing this is proper But he had a wagon with larger brakes out back...
8ball is offline   Reply With Quote
Old 04-16-2014, 11:14 PM   #114
bobbycos
my parts list is what i used on my coupe
Old 08-24-2014, 04:31 PM   #115
JaberCB7
JaberCB7 is cool... so far.
Send a message via MSN to JaberCB7
find myself using the same DIY twice... my sedan will come together nicely. Thanks man
Originally Posted by Uncle Willey View Post
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
JaberCB7 is offline   Reply With Quote
Old 09-04-2014, 11:01 PM   #116
AmznAzn
AmznAzn is cool... so far.
ok, back from the dead. I'm going to the junk yard tomorrow. So what 6th gen accord should I be looking for it to be direct bolt on in the front? Is there a specific year (2001?), Obviously 5 lug spindle, v6? Coupe or non coupe?
Sorry but the pictures really confuse me.
^MRT^
AmznAzn is offline   Reply With Quote
Old 11-04-2016, 04:46 AM   #117
Losiracer2
Does anyone know if I'll have issues with using a front knuckle off an 03 Acura CL? It uses larger 11.8" rotors so I'm thinking in order to use my Legend GS 2 piston calipers, I'll have to use the CL front caliper brackets and pads.
What about the hub offset, will it still match the CB7 offset OK? I'm planning to run 2g 17" 5 spoke 01-03 TL-S wheels initially.
The rears I've got Prelude 97-01 hibs and 02 Accord V6 rotors.
member's ride thread
99' Lexus LS400 148k VVTi V8 gets up & goes...new DD
97' Lexus LS400 298k.....selling soon
96' Honda Odyssey 196k miles...$485 spare van for my parents
Old 06-12-2018, 01:52 PM   #118
Accord1320
Accord1320 seems to have made some friends! Accord1320 seems to have made some friends!
2 prelude rear hubs
2 crv rear drums
10 lug nuts
that is all
The 97 to 01 prelude hubs... Type SH or Non-SH?
"There are only two types of people in this world... Those who run & win, and those who sit at the sidelines & watch the winners pass them by."
My YouTube Channel! - There's more videos here!
Check 'em out, hit LIKE, or even better, stay updated with more vids when you SUBSCRIBE, including vids of my JDM H23A swap!
Accord1320 is offline   Reply With Quote
Old 06-12-2018, 02:05 PM   #119
Jarrett
Doesn't matter.
Old 07-14-2018, 01:54 AM   #120
Accord1320
Originally Posted by da9b16 View Post
I also feel confident that the rear 5 lug hub from an oddy is a better fit for the rear drum and actually has a deeper seat for the nut to sit in like the cb/ cd does and makes for a better fit. I was getting ready to do 5 lug on my wagon and found this out.
I tried using the Prelude hubs (bc Oddy hubs are hard to find) with CRV drums, but the drum does not sit fully flushed to the hub. (There's about a quarter-inch gap between the hub and the drum.)
Will I need to grind off a bit of the edges from the hubs to properly seat the drums onto the hubs?
Just also wondering if anyone else ran into this because my lugs have less to little thread for the rims to hang on to...
