i have a 1990 cb accord jdm with the f18a carby engine, does anyone know how hard it would be to convert it to efi? or if there is a webber carb for it? i cant find much for this engine its a pain in the as haha!
1990 carby to efi conversion?
"How hard" is fairly subjective.
However, I've heard from a few fairly experienced people that it's far too much work to bother. It can be done, but it's a major hassle... enough that it might be better to just buy a fuel injected CB instead.
The majority of the members here are from the US and Canada, where we only got the fuel injected F22A engines. Because of that, unfortunately, there's not much info around regarding the carb'd models. evil_demon_01, one of our moderators, has some experience. He may be able to help a bit.
Hey Man, from NZ too.
In all honesty it really isn't worth the conversion.
Buy one that's already EFI if its what your wanting.
Whats the reason for you wanting EFI?
The carb works fine, If you looking for a bit more power, throw a cam in it, and mill the head.
That's really as far as you can go for cheap and simple mods.
Otherwise your looking at high comp pistons, and Holley carb
My 5.7 LS1 Holden Ute
Originally posted by deevergote View PostBisimoto was VERY successful racing with a carb'd F series for many years. He converted to fuel injection eventually, but the carb was his thing as he was earning his reputation in the scene.
If you want more power, I say upgrade to the Holley carb, and swap in an F22A.
Intake ports are different between the two heads.
Actually you could do F22 block with the F20 pistons and head, which will bring the compression up to 9.1 if I remember right.
