Darken trim molding.
    Your can try the trim black paint... wont fade anymore.
    New one cost alot so try to avoid that... unless your pockets are deep enough.
    Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
      look up member "Type G" i think he has a thread where he talks about painting his...might have to wait till u get your 30 post though
      Ride List
      1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
      2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
      newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
        I would either use Mothers or McGuires back to black trim detailer if you don't want to paint. It works really well. I use it every time I wash my car.
        Members Ride Thread: LX ~ EX ~ For Sale Thread
        Sold to: accord=inspire? ~ Accord214 ~ Raf99 ~ daheavyking ~ OHOYAMA ~ JunyAccord ~ CBsevenTUNER
        Bought from: Joshy ~ TypeG ~ agol ~ 92smokeaccord ~ Extacee ~ mak ~ lindiz ~ illestatus ~ F20A CB7 ~ accord=inspire? ~ marcusv8thunder
          Originally posted by preludebro View Post
          Yeah I really don't want to pain it... I've had previous experiences as the paint chips off... Unless what I used wasn't adhesive enough. I'll browse around and thanks for some pointers
          You probably did not sand or prep the surface before painting it that's why you paint flake and fall off.
            if you paint it your deffinatly gonna need to get some plastic paint adhesive. i have a can of it in my garage but i havent used it yet so i couldnt really tell you how it works. im pretty sure you just spray it on before the paint
            THUG LIFE!!!!!!
              please dont catch your car on fire. i would find some extra molding to use first. just to see if it will have the same results.
              not sure if our moldings are made from the same plastic/rubber as these jeep flares. but worth a try.
              "My FOR SALE thread - Click here"
              MEMBERS RIDE
              99 SILVERADO
              WHEEL FLIP
                the lil piece of molding on the front fender and the one on the door (coupe), seems to be made slightly different. i dunno maybe its just my car but the lil one gets a faded gray color but stays shiny and the big one gets a dull flat faded black...its hard to explain lol ill see if i can get some pics...i ususally use the mothers BTB. but i think painting is the best way to go...just make sure u prep correctly...and i dont think the fire method will work the same as that vid.
                Ride List
                  Nah, I tried it on mine. The rubber just melts and doesn't get any more black. Works for the bumper molding and lip though.
                    Painted mine with no problem. Does take some time a patience though. I got black auto trim paint at Advance Auto but could get at any auto store. Some people tape and some take it off. I took mine off but you have to be careful removing the molding on the doors. Its easy to break the clips that hold them on. Would rather buy new clips then new paint job. This will give you the best longest lasting results.
                      http://www.cb7tuner.com/vbb/showthread.php?t=98604
                      TypeG. is the man . check link and be amazed.
                        I just used some orchards flat black and just cleaned it really good
                        [IMG][/IMG]
                        MRT: http://www.cb7tuner.com/vbb/showthread.php?t=196248
                          I painted mines with blakc caliper paint and primer. and a good sanding and tack rag. its a matte finish which looks exactly what it would look like with tireshine. 6 months later still looks semi glossy. never had to apply tireshine again. which is good because dirt wont stick to it.
                            FOREVER BLACK for the win. This is more like a dye in a polymer fluid. Works wonders on faded plastic and lasts..well..forever. Applied with an on bottle, applicator sort of like liquid shoe polish applicator.
                              a heat gun works wonders on our side moldings. Mine used to be a light grey, then i used the heat gun and moved it back and forth like a spray gun and it brought them back to life
                              MR THREAD: http://www.cb7tuner.com/vbb/showthread.php?t=196078
                                the fender and quarter mouldings on the coupe's are just molded plastic. The door mouldings are all moulded plastic with metal reinforcements on the inside that make them a little stronger. The door mouldings can bend and damage easily if removed improperly.
