I would definitely be on board with a hytech replica for the f22!!!
hytech replica header for F22A/H23A1 non-vtec
this header would be considered a tri-y eh.
4-2-1's are the ones EVERYWHERE--v
the reading ive done on hytech's design shows improvement across the whole power band, unlike just the high end potential of the 421's, Im guessing this would benefit the f22 just like the h22, perhaps not as well from inherent flow issues whatever they may be motor vs motor.
as for the cross member issues ive only seen those come up with the prelude.
this is the header design ill be implementing original or replica for my swap, for my f22 car this header would be great and a nice change up from the punch press 421's saturating the scene.
In essence make it so, but please design the slip fit out, maybe where that union is smaller style V-band clamps could be used.
edit: one other issue with this too is the collector, the h22 hytec/rep's use a 2.5" Type R ball collector finding the header collectors to mate this to the rest of the piping are a pain to find and expensive. would the F version carry on the 2.5" style? or drop down to 2.25 and a flange. just something to chew on..Last edited by illinois_erik; 01-31-2013, 11:13 PM.
http://vibrantperformance.com/catalo...roducts_id=565
This was the donut gasket kit that I used to make an adapter pipe to mate my Bisimoto header to my stock exhaust @ the time. Had to open up the holes slightly, but it worked pretty well. Visually, it looks spot on to the PLM flange. This kit was a pain to hunt down locally but I did get lucky at the time.
Originally posted by Granite CB7 View Posthttp://vibrantperformance.com/catalo...roducts_id=565
Originally posted by illinois_erik View PostYikes 60 bones. Ive seen those too but on like jegs and other places, its a ball flange i suppose. if just that is that much, then the complete one ive found on the bay for 70 isnt so bad afterall and its stainless
Originally posted by Accrdwgnguy View PostIts worth it, no doubt it would last alot longer than a flex pipe.
unless you like cracks and failing flanges. even if its just a 4" wide one, you cant have a rigid exhaust header to muffler on a DD and expect it to last, unless you like crawling under your car often dicking with the stodgiest system on it lol
I don't know manu header companies. But I see a lot of 4-2-1 styles. Where the 4-1 styles at? Like Kamakazie..**Blk Housed Slut Crew Member #1**
Why is the type of flange any kind of issue? If you can go through the trouble of getting the right type of donut flange, or whatever it's called, onto whatever exhaust system is on your car, why not just cut the thing off and put a standard flange on there?
And... Tri-Y and 4-2-1 are the same thing. You can see that with your own eyes. Whether they're a cheap model with a flange doesn't matter. They go from four headers, then merge into two, and then finally into one. For the sake of flow, the collectors have to be of the Y-shaped variety.
Originally posted by illinois_erik View Postwell yeah, where the hell did flex pipe come onto radar? the thing i posted is pretty much the same as granites suggestion only you get more metal to work with, and I highly suggest some sort of braided stainless flex after that collector,
