Originally posted by 92HondaEX
SUSP: Taking that POS rotor off
go to napa or checker or autozone whatever auto store is near you and buy a ball joint separater its much easier to use and safer than jacking up your rotor and they dont cost very much, good write up still. glad to see at least someones trying to do this without having to pay a fortune. good job man.im finally back in a cb7 its like coming home.lol
93 ex accord coupe h22 SOLD
90 ex accord 4 door SOLD
91 se accord 4 door SOLD
92 lx accord coupe SOLD
93 ex accord 4 door SOLD
92 ex accord 4 door h22 SOLD
93 ex accord 4 door auto SOLD
92 ex accord coupe auto
Originally posted by ray raygo to napa or checker or autozone whatever auto store is near you and buy a ball joint separater its much easier to use and safer than jacking up your rotor and they dont cost very much, good write up still. glad to see at least someones trying to do this without having to pay a fortune. good job man.
get a pitman puller...not the ball joint seperator because the seperator is jsut a fork type bullshit and it could damamge the balljoint boot. it also made a hole in my dut shield so whenever i take hard right turns, the dustshield hits my rotor and causes what sounds like rattling cans.
i even tried a 2 jaw puller but didnt work...id HIGHLY suggest my way.
Originally posted by wed3kget a pitman puller...not the ball joint seperator because the seperator is jsut a fork type bullshit and it could damamge the balljoint boot. it also made a hole in my dut shield so whenever i take hard right turns, the dustshield hits my rotor and causes what sounds like rattling cans.
Originally posted by wed3kjesus christ, every time i try and explain shit to you...you get hella confused. forget it.
Originally posted by 92HondaEXOk....this is what I do understand, when you put the four bolt in the back and bang on it, you remove the hub, rotor and bearing as one piece, right? So now you have the bearing, rotor, and hub off the steering knuckle, do you use that bearing puller to get the bearing off the assembly(rotor, hub, and bearing assembly)? That's is what I understand, and sorry that I'm getting so confused.....
no bearing remover required unless of course you need to change the wheel bearing and in that case, id get that part pulled out.
what was kinda funny is that i proved my shop teacher wrong by going with this method.
What the hell, I can't get the hub assembly off of the knuckle. Banging it with those 60mm long bolts ain't doing anything. Any suggestions? Bang harder? I'll be damned if I'm taking the whole knuckle somewhere for someone to do it.Metal Metal and more Metal!!!
How much does your wheel/tire combo weigh? Post here!
-=Suicide Crew Member #1 (only member so far)=-
MY RIDE
"I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
Originally posted by uslspctWhat the hell, I can't get the hub assembly off of the knuckle. Banging it with those 60mm long bolts ain't doing anything. Any suggestions? Bang harder? I'll be damned if I'm taking the whole knuckle somewhere for someone to do it.
i had a really big hammer (as seen in the vid)...so idk what to tell you.
