Originally posted by CB7/KA8
View Post
f22a6 head with f23a1 block.... i am opened to any advice or suggestions.
Originally posted by PR CB7 View Postits been done, with a h22 head a couple of times
i havent seen this with a f22 head, this is cb7t only build
f23 head gasket(hg)
NO,NO,NO
this setup, will yield your static compression to 12.35:1
PT6 will never be able to handle it
jdm h22 obd1 injectors are needed
also a thicker headgasket (maybe)
chipped p06 with a high compression map, 12.3 is no joke
you'll be fine with that cam, i suggest bisi teflon spacers
this is a build you cant just put it together, do some more research on this
and i'll guarantee you'll have one of the baddest sohc's here
I'm not sure if anyone on this forum is familiar with HANDCOMMAND ecu but my bro bought a p28 w/ Type R base map for his H22A swap and got it tuned. I may just get one of them but what mapping should i have him do?
What are the teflon spacers?
Thank you for your inputs.
Originally posted by CB7/KA8 View PostThis is almost my exact build. The only difference is that I have Wiseco high dome K20 pistons.
Originally posted by gloryaccordy View PostWhat is the deal w/the offset on those? Did you have to flip the pistons around/get them machined?
Originally posted by 91-accord View PostHow's the results of your build? I'll eventually up grade the pistons. thanks for your inputs.
1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
id keep the balance shaft because itll help your long term reliability. unless you balance your entire rotating assembly perfectly and get a block girdle
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.
Originally posted by 91-accord View PostHas anyone successfully done a similar set up before? I would like to know numbers.
Originally posted by CB7/KA8 View PostNope. I didn't have to flip them. Most people think that you have to flip them 180° because the k series motor turns clockwise and our motors turn counterclockwise. That's a misconception. The motors actually turn the same way, toward the header. The k series header is in the back which makes it seems as if the motor turns in the opposite direction as F,H motors.
Right now it runs choppy and it bogs because I'm not getting enough fuel. I still have to install my fuel pressure regulator and I have to find some H22a or 450cc DSM injectors. Then I have to get it tuned. I'm using a chipped P06.
Did you clay this motor to check your valve to piston clearances? If you did can you post what the clearances are? I'm just curious as I once looked into using K pistons but opted for a custom set. Just seemed too be a bit risky.
Originally posted by blazedealh91 View Postcould you sare ur base map am doing the same build
Originally posted by GhostAccord View PostHonestly, I always thought they rotated them 180° in the hole becuase the K20/K24 pistons had a different offset for the wrist pin. As for the machining myth. I heard/read that they required machining becuase the valve reliefs are cut at different angles. The K20/24 use a different valve angle than the H/F series.
crank length + rod length + compression height = piston height.
1.91 + 5.47 + 1.18 = 8.56 in. (217.42mm)
The crank length is half of the stroke.
My deck height is 219mm so my pistons are 1.56mm in the hole. Also, I'm using aftermarket K20 pistons with extra deep valve reliefs.
Originally posted by GhostAccord View PostNice to see someone using formulas to plan their build. I know that formula very well. I use the term Crank Throw instead of crank length though....Same shyte different pile.
What cc is the dome on the K20 Wiseco that your using? and what rods are you using that are 138.9/139mm?
Originally posted by GhostAccord View PostI knew the rods had to be something other than an H or F series.
Originally posted by blazedealh91 View Postdid u use a stock f22 headgasket
I finally finished it up over the long weekend. I just have to re-adjust the valve lash and get it tuned. I drove it around the block (less than a mile) and it pulls hard. As soon as I tap the gas it wants to take off like a rocket.
