While installing my F22 P. S. Speed Sensor on the M2Y4 (most people on here call it the VSS, although that's on top of this), the bracket for the bolt snapped right off during tightening!
I could not believe it when I heard the snap. I thought the sensor was all the way in! The replacement part is $188 on Majestic Honda
I started reading and researching and I found some posts by Loisracer2, lindz, and others. Loisracer2 always advocated for the H23 version of the part, and said he had no issues with the speed reading. Along the same lines, I have heard that they all (F and H series versions) have the same teeth (19?) if USDM built to read mph. Lindz took a picture of both shafts (from the H she was installing and her F), and her H version had 21 teeth and the gear was longer as well. I'm guessing that is because her H version was reading km/h, but it's not clear.
I guess I have many questions.
How do you know when the P.S. Speed sensor is fully in and meshing with the differential correctly? Would some transmission fluid on the gears and a rotating action of some kind help with the installation?
Part questions: The part number for F22 and H23 P. S. Speed Sensors on Majestic are exactly the same. Should I be getting one of these as a replacement for my broken one, or an H22 variant, since I now have an H22 M2Y4 tranny? If I have to loop the lines to the sensor, then I will, I just want the right part for the new tranny.
Thanks all, for your help.
