Old 12-11-2017, 03:16 PM   #1
bseballkid1990
bseballkid1990 is cool... so far.
bseballkid1990 : 1992 Accord EX
I picked her up almost a little over a year ago. I picked it up for around $400 and all it needed was a fuel pump.. which came with the car lol.
Engine/Trans :
H23A
Skunk2 Pro Intake Manifold
Skunk2 70mm Throttle Body
ESP Alternator Relocation Bracket
AEM Fuel rail & FPR
FID 630cc Injectors
KS Tuned Tensioner
KS Tuned Walk Blocker
Hondata Thermal Gasket
Skunk2 Alpha Radiator
Fidanza 9lb Flywheel
Clutchmasters Clutch Kit
Exterior :
Stock for now
Interior :
Stock for now
Suspension / brakes / wheels :
Spc front upper ball joints
5 lug conversion using
Odyssey front knuckles
Prelude rear hubs
17x8 +65 Konig Hypergrams
ESP Traction Bar
Audio / electronics :
Future plans :
Tein coilovers
I can't find the pics when I first picked it up but here it is in the back of my old work halfway through replacing the fuel pump.
After I got it running I started working on the 5 lug swap. here it is halfway through. lol
and once I finished the 5 lug swap I got it some new shoes.
I took out the old F22 which had a bent valve for a H23 and here it is at the track.
I'm missing more picture but I'll update those in a bit.
bseballkid1990 is offline   Reply With Quote
Old 12-12-2017, 06:22 PM   #2
Rilas
Looks like your off to a good start! Keep up the good work!
Old 12-13-2017, 08:39 AM   #3
Bunta
Bunta is cool... so far.
Looks like it's in pretty good condition, especially for $400. Did you manage to get some decent runs in at the track with the new engine?
Old 12-13-2017, 09:53 AM   #4
bseballkid1990
Here's a couple pics from when I took out the f22 and put the H23 in.
Old 12-13-2017, 09:55 AM   #5
bseballkid1990
Thank you!
I did but the stock clutch was slipping and since then I've installed a stage 3 clutch and lightweight flywheel. trying to get it prepared for the track in the spring. I've got to put in the half radiator, delete A/C, install the drag headers/exhaust, and finally get it tuned!
Old 12-16-2017, 02:56 PM   #6
'93CB7Ex
1v1 me at the track with my k24 ha
Old 12-28-2017, 10:31 AM   #7
bseballkid1990
You don't want it.
Old 12-28-2017, 10:32 AM   #8
bseballkid1990
This was a few weeks back when we got our yearly little bit of snow.
Old 12-28-2017, 10:37 AM   #9
bseballkid1990
Finally took out the old leaky radiator, ac condenser, and busted fans. Installed a new skunk2 alpha radiator, fan, and new upper hose. I had to get a hose at autozone and cut it in order to fit. Does anyone know if there is a direct fit hose for the single sided radiators?
Next will be to install the drag headers and exhaust after I get the new Aem fuel rail, injectors, FPR, and AEM Air Fuel ratio gauge.
Old 12-30-2017, 08:53 PM   #10
'93CB7Ex
couldnt use the oem upper hose?
Old 12-31-2017, 06:49 AM   #11
Raf99
I found out the hard way too that there is no direct hose to fit the upper if you go with a skunk2/mishimoto half rad. I had to get a custom one too.
Looks great man!!
Old 01-02-2018, 08:44 AM   #12
bseballkid1990
Nah, it kinked too bad and didn't sit right.
Looks great man!!
Yeah, I went to vatozone and tried to get one with a similar bend but even that isn't working so great. but at least I could get it running and the coolant bled. this fan MOVES so much more air than the OEM lol
Old 01-04-2018, 01:06 PM   #13
Raf99
If you ever experience any overheating issues or rad fan on all the time etc. it's because you now have a huge open space next to the rad. Air will take the path of least resistance and will most likely bypass your whole rad. It may be enough of an issue that you'll have to block it off. But you may be ok.
Old 01-08-2018, 08:43 AM   #14
bseballkid1990
That's a good point. I haven't had any issues so far but it hasn't been above freezing here in Georgia the past couple weeks so maybe that's why. I'll definitely keep an eye on it. But in other applications I haven't seen a block off to funnel air through the radiator.
Old 01-08-2018, 09:57 AM   #15
bseballkid1990
Splurged a little bit for christmas lol. Now do I spray it or go boost?
Old 01-08-2018, 10:05 AM   #16
bseballkid1990
did you have to do any blocking off with yours?
Old 01-08-2018, 12:45 PM   #17
illinois_erik
Ive had a half rad for a while now, never had issues even in the past summers. Temp gauge sits where it normally does. the only difference is i have a fan shroud... room for ram air ducting..coming soon.
Old 02-05-2018, 08:43 AM   #18
bseballkid1990
Got my ESP alternator relocation kit in and installed
Then the other night i hit a pothole that came out of nowhere
Old 02-05-2018, 09:50 AM   #19
Jarrett
Sorry to hear about the bent rim. I know nothing about fixing flow-formed wheels, either.
But you're making good progress elsewhere! Did you ever finish up redoing your fuel system?
Old 02-05-2018, 10:39 AM   #20
NH-503P-3
NH-503P-3 is cool... so far.
Can you keep your AC compressor and mounting bracket with the ESP alternator kit? That sucks about the wheel. Car is coming along good.
