Originally posted by Nomad93
View Post
f22a1 crank but no start
Originally posted by dj_ender View Post
Originally posted by sonikaccord View PostI think your ignition system is good enough. The only other things left to check are timing, fuel and compression.
Do you have 12v at the ylw/blk (colors may be wrong, I forget) wire on the injectors?
Does the car just keep cranking? Is there any signs that it's about to turn over?
Originally posted by Nomad93 View Postjust bought a circuit tester should i test yellow and blk wire on the fuel rail that holsters all injectors??
