ayye so i just picked up a 93 accord car was running fine with a slight jump in RPM while warming up but i fixed that by cleaning IACV. noticed that the o ring on my distributor was leaking and pulled that and replaced it car started got me home and to work the next day and no i have a crank with no start situation. it does start occasionally but quickly bogs itself out especially when i hit accelerator, asked a friend who mentioned to give the distributor a bang or two while cranking it and it may start... which in my case it did so i immediately went and got a new one but installed and same problem happened no start!!!!??? (i also put in new fuel filter)
f22a1 crank but no start
Originally posted by sonikaccord View PostIs the ignitor new?
How are you testing for spark?
Originally posted by Nomad93 View Post...i have my ignition coil pulled its a external unit and i can't seem to get any readings off of it with my multimeter...
Originally posted by Nomad93 View Posti replaced the whole distributor all new parts. all wires in correct order and i have good spark along with that i know that the rotor can be 180 deg. off but the distributor i bought only allows it to go on one way NO CEL.
