Cruise control is not working
    So i just got a call from my brother telling me his cruise control stopped working and that the light on the cluster doesn't work anymore
    I was wondering if anyone has actually had this problem and tried to fix it and maybe a place to start at.
    i have. after checking all the fuses. i picked up a few cruise control/sunroof switches from the jy. replace the switch, and i now have cruise control.
    "My FOR SALE thread - Click here"
    MEMBERS RIDE
    99 SILVERADO
    WHEEL FLIP
      If the switch isn't the problem, other things to look at would be the cc unit under the dash and the actualtor itself.....
        Tell him to make sure it's actually turned on on the dash. When I bought uzume, my buddy told me the CC didn't work. Within a week, I'd pushed the button on the dash, set the cruise control and sent him a video of it working. It's very easy to turn it off without noticing when cleaning the interior.
          i just switched out my cc switch for the one with the cc/sunroof button. Its a cosmetic thing but my orig has only 100k on the switch (so if he doesnt have the sunroof or it doesnt work you can get my old switch) just let me know
            Hmmm thanks for that tip, ill be sure to swap my cruise control switch with his.
            Yeah i double checked that on the phone . That is actually even more likely in his car because the green light in the switch doesn't work anymore
            Yeah this is an EX so we need a sunroof switch
              Alright i finally took a look at it yesterday and figured it out
              There is a switch for the cruise control on the clutch pedal and a rubber bumper ( The same way the brake light switch on the brake pedal works ) and the rubber bumper had fallen off so the sensor was extended. This causes the cruise control to think the clutch pedal is in all the time so it didn't work
              I replaced it with one of those plastic clips that holds your door panel on and tada it worked great again. Just an FYI for future people who might have this problem.
                rubber nipple!
                mine was because of the rubber piece cam off fixed now!
                www.myspace.com/spayellowaccord This is mine!
                www.myspace.com/autorevolution This is our car club!
                1. 1992 Spa Yellow Accord EX 5spd coupe. I <3 My CB'S
                2. 1992 Grey Honda Accord DX 5spd coupe. I <3 My CB'S
                3. 1992 ? Honda integra Xsi DA6 im so jdm i sleep on my right side.
                4. 1993 Black Honda Civic Hatchback. love my EH
                  I had the same problem, but found the solution to be that I had a brake light out... who knew?!?
                  Current
                  1992 Accord EX 5-speed Sedan
                  Rosewood Brown
                  1992 Accord EX 5-Speed Sedan
                  Arcadia Green
                  Previous
                  Bordeaux
                  1993 Accord LX 5-Speed Sedan
                  Bordeaux
                    Fun fact:
                    The cruise control button gets hot after prolonged use.
                    I've never left the button on and CC off, but if you go for a few hours with CC activated the button puts off some decent heat.
