I was backing up out of my driveway yesterday and my car shut off and the oil and battery lights turned on. It still won't start and my dad cannot figure out what's wrong. Confusion. Any suggestions as to what could be wrong?
Car died. :(
Originally posted by tangowombat View PostI was backing up out of my driveway yesterday and my car shut off and the oil and battery lights turned on. It still won't start and my dad cannot figure out what's wrong. Confusion. Any suggestions as to what could be wrong?1992 Prelude S w/swapped H22A
Starting fluid. If the engine isn't getting fuel, spraying a short burst of starting fluid into the intake will supply enough fuel to start the engine briefly. If the engine starts on the starting fluid, then you know that you're problem is in the fuel system. If it doesn't start on the starting fluid, then you need to check spark, verify that the timing belt is good, check compression etc.
