Okay, so I have a problem where my battery will not charge at all, new alternator, tested and passed, I did a wire tuck and I did it right, cut wires one by one, resolder and sealed it all up, I turn my car on, and it shows battery voltage at 12.4, checked it at fusebox and starter, 12.4, I tested the voltage of the black and yellow wire and it was at about 12.1, and at the alternator plug it is at 11.9, when the car is at idle, the voltage slowly drops, and drops more after I out a load on the alternator with lights, radio, ect, I just can't figure out what's wrong, please help!
battery not charging, alternator, starter, and battery are new.
Sounds like it could be a short somewhere.
Wire tucks make it difficult to track down shorts.
If it is a short.
I would start with your cleaning your terminals for good contact.
Does your battery light stay on after the car is started?
I'm leaning towards a bad solder somewhere or you overheated some wires and blew some fuses.
Those are all worth checking out.
Good luck
Did you check the alternator fuse? (red box)
I don't have my service manual handy, there should also be a fuse in the box under the dash.
Now that I think about it, is your belt tension right? With the engine running you should be reading about 13.5 to 14 volts off the big white wire on the alternator and battery terminal. If your belt is too lose it won't turn the alternator fast enough to generate a chargeLast edited by ADD/Andy; 12-03-2013, 12:32 AM.
sorry guys i couldnt really worok on my car with all this snow, but, yes, my main fuse (80 amp) is good, upgraded all grounds to 2g wire, would you happen to know if there is another fuse under the dash that the alternator needs? i was thinking that maybe i could disconnect the original output wire on the alternator and run a new one with an inline fuse straight to the batery, could that work? i just need it running fr now untill i can find the actual problem itself
Download the FSM. Check for the voltage sense wire on the alternator. The alternator isn't putting anything out because something isn't telling it to do so. Check to see if the wires on that plug of the alternator is in specs with the FSM.
Report back, you will find the issue.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
