I just recently did a swap on my 92 accord. I put a JDM H22A in the car with an f series tranny. I drove the car two hours home from where I was when we did the swap. I drove the car for about 3 days ok no problems, vtec kicked in fine and shifted normal. By the fourth day of being home it started to act up. It acts like its fuel cutting. I found the other day that one of the O rings on the fuel injectors was leaking fuel on to the intake mai, so I replaced it. After driving it today it still dies, spudders, and will shut off after coming to a red light. On my way home my dad followed me and its slowly died and it wouldnt stay running. It would just chug along and die. Now, with that being said I've done some other research and found that its possible the accord fuel rail I used isn't right. This was quoted on here on a post i found. "One thing you have to remember is injector flow ratings change based on fuel pressure. 345 cc at 43 psi is what the h22 injectors flow at.....but the h22 FPR is not a 43 psi one, it is at 36-38 psi which means those 345cc injectors flow at 310cc.
if you used the accord fuel rail you are probably running accord fuel pressure with the 370cc injectors, meaning way too much fuel since the injectors are 25cc larger and running a lot mroe pressure than stock." I'm not totally sure if this is the problem. But I am running the accord fuel rail withn the H22 injectors and FPR. Could this have caused my problem for it dying? Everything that I quoted the person said seems exactly what is wrong. My other question is, would this cause my injectors to be fried and I need new ones? I'm unsure exactly if my ecu is a p13 or 28. I ordered it from pherable.net and its a chipped ecu running on a base map and I haven't had it tuned yet. I'm going to if this is all the cause of my problems.
