Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 07-08-2008, 11:28 AM   #1
lucid
lucid is cool... so far.
lucid : 1992 Accord EX
The Endless Evolution of the Sleeper Sedan Project...
new pic- July '09, freshly lowered and a little dirty.
MOD LIST:
//ENGINE: -see post #12 for pics
[ 91 JDM H22A ]
Stock Low Mileage Block
ARP Head Studs
Custom Ported and resurfaced head with reshaped and polished combustion chambers
>KMS Silicon Bronze Valve Guides
>Skunk2 Racing Valve Springs
>Skunk2 Titanium Retainers
>Skunk2 Hi-Compression Flat Face Valves
>Skunk2 Stage II Camshafts
Polished Valve Cover and Cylinder Head
Manual Tensioner Conversion
All New Tensioners, Belts, H2O pump, Plugs, Wires, etc. from HONDA
All New Engine Gaskets and Seals
//INTAKE:
EBay Prelude CAI, half installed
Skunk2 68mm Throttle Body
Custom Ported and Matched Stock Intake Manifold
>Custom Standalone IAB System using an Adjustable Shift Light as Trigger
KMS EGR Block-Off Plate
Phenolic Intake Manifold Gasket
//EXHAUST:
EBay SS Header
Gutted Cat (aftermarket planned)
SS Catback 2 1/4" Exhaust piping
Thrush Turbo 2 1/2" Muffler
//POWER TRANSFER:
[ JDM M2B4 LSD 5-Speed Transmission ]
Fidanza Lightweight Aluminum Flywheel
Exedy Stage I Clutch and Pressure Plate
New HONDA release bearing and MTF
New Axles
//EXTERIOR:
This List is Minimal to Maintain SLEEPINESS!
Original OEM HONDA Rain Guards
Reinstalled Stock corner lights- 9/08, ordered full amber
Clear Front Bumper Lights, with stock-style lenses, going stock again with corners & DIY blackhoused and projector retrofitted headlights soon
Custom Grill Hack
JDM SiR badge
LEGALLY tinted windows
Black CB7Tuner.com Decals Hiding in Rear Side windows
repainted wiper arms black- 9/08
//INTERIOR: -see post #9 for pics
96 Prelude Si Seats, Custom Mounted to Original Accord Bracket & Sliders
99 Prelude Instrument Gauge Cluster Swap
Immobilizer "Key" Icon in Cluster wired to VTEC Signal
Full Custom Orange LED Conversion, Including Prelude Cluster, all Switches and Interior Lights
Resistors for LEDs are wired into car Harness, not buttons- to isolate heat from bulbs
Custom Climate Control with LEDs, Tint, and Polished parts
Polished Plastic Interior Parts, Door Locks, Window Switch Panels, Dash Vent Faces, Glove box and Button Trim
Door Panels Dyed Black
Tan Vinyl wrapped Front Door Pockets
Complete Prelude Shifter Assembly with shortened and rethreaded lever
DIY solid shifter bracket mounting
//SUSPENSION:
Eibach Sportline Springs
Tokico HP Blue Shocks (fr)
New KYB GR-2s in back (replacements), May, '09
Prothane Polyurethane Bushings, (The ONLY) Complete Kit for 90-93 Accords
Ingalls adjustable (0-1.5*) Front Upper Ball Joint Camber Kit
Wicked Tuning adjustable Rear Upper Control Arms
EBay Front Upper Strut Bar
EBay Rear Upper Strut Bar
EBay Rear Lower Tie Bar
DIY Solid Polyurethane Front Engine Mount
//WHEELS:
Stock EX, with Falken 205/50/15s
Stock Prelude wheels on hold until brake, bearing and spacer swap
//AUDIO/ELECTRONICS:
JVC kda205 (i think) cd receiver, custom amber illumination at night and tan during the day!
Kenwood 6 1/2"s in front, wired as separates via...
Kenwood component crossover and flush-mounted tweeter in door
Kenwood 6x9"s in rear deck, in stock bracket/grill housing
Rockford Fosgate "prime" 500x1 rms amp
2-12" Infinity Kappa subs in a sealed box, mounted to rear strut bar
//BRAKES:
Swapping to Cl hubs, longer wheel studs and Prelude VTEC Brakes...8/14/09
EX 4-Wheel Disc Brakes, cross drilled/slotted rear rotors w/ hawk HPS pads
ABS System removed
Converted to Stock Standard Proportioning Valve and Lines, Modified to match ABS MC
New 1" Brake Master Cylinder
Need to install my RS Integra 40/40 valve!
//UNINSTALLED PARTS:
New Stock "Accord" and "H" emblems
Prelude Vtec Front Brake Calipers & Brackets
New Front Wheel Bearings
Eibach 5mm Pro-Spacer wheel spacer kit with extended studs (for Prelude Wheels)
R12-R134a retrofit kit
see pics on pg.3
//FUTURE PLANS:
Buy Depo Red & Clear Tails- No Longer available ::
Install Luxeon Single-Bulb LED Tail/Brake Lights
Fabricate Tan Vinyl Shift Boot
Wrap Tan Vinyl over center panel of front doors
MSD SCI Ignition
Custom ECU Tuning
Prelude Brake Swap-in progress.
Prelude Wheel Swap, courtesy of my SiVTEC Prelude (need another spacer kit for rear)
Progress rear sway bar
//ACCORD BASED DREAMS:
This car is not a dream, it's for reals!
Turning my H22A1 and F22B into a rebuilt ported H23VTEC!!!
Driving this car forever.
The H22 Sleeper Sedan, updated 8/14
After 4 months down...It's back! and tucked.
Need a Swap or some work done in the DC/MD/VA/WV area?
PM me and get it done right!
lucid is offline   Reply With Quote
Old 07-08-2008, 12:57 PM   #2
accordtypeR
Accord of the Month: August 2008
accordtypeR is cool... so far.
Send a message via MSN to accordtypeR Send a message via Yahoo to accordtypeR
im trying to make sense of this.
My Old Baby
SOLD TO
accordtypeR is offline   Reply With Quote
Old 07-08-2008, 01:57 PM   #3
texasvtak
Southern Regional Mudder Hater
texasvtak seems to have made some friends! texasvtak seems to have made some friends!
Send a message via AIM to texasvtak
He typed it all up, probably made the code overly complicated in an attempt to make it look good, may or may not have succeeded at that, but was somehow logged out before he hit submit. Its happened to me before. Sucks when its something you spend time on.
To-Do List for Today
Be Awesome
texasvtak is offline   Reply With Quote
Old 07-08-2008, 05:38 PM   #4
lucid
There is no overly complicated code here, my friends. I simply spent too long typing and was timed out by the time I went to post.
Old 07-08-2008, 05:44 PM   #5
JoshM
Moderator
JoshM has a HUGE cock! JoshM has a HUGE cock! JoshM has a HUGE cock! JoshM has a HUGE cock!
Send a message via AIM to JoshM
Well, all is clear now.
Post some pics up!
JoshM is offline   Reply With Quote
Old 07-08-2008, 06:52 PM   #6
new_beginnings
Parts Masta
new_beginnings seems to have made some friends!
Send a message via Yahoo to new_beginnings
Another Virginian in da house.
Trev.
RETIRED...
new_beginnings is offline   Reply With Quote
Old 07-08-2008, 07:08 PM   #7
oneoffaccord
I Need Pics.
Old 07-08-2008, 07:24 PM   #8
JaK FRoSTWhiTE
Event Staff
JaK FRoSTWhiTE is cool... so far.
Send a message via AIM to JaK FRoSTWhiTE
pictures please.
JaK FRoSTWhiTE is offline   Reply With Quote
Old 07-09-2008, 01:18 PM   #9
lucid
INTERIOR:
tan doors dyed black, tan vinyl wrapped door pocket, polished parts, etc.
tan Prelude seats! Painted b-pillar black to match black doors.
new nighttime dash pic, 10/08
Old 07-09-2008, 01:49 PM   #10
kamaccord
kamaccord is cool... so far.
Very nice ride and modifications.
600HP" 1990 ACCORD LX COUPE COMING SOON
CLICK HERE TO VIEW MY 1990 CB7
kamaccord is offline   Reply With Quote
Old 07-09-2008, 02:07 PM   #11
coletrain
coletrain is cool... so far.
Send a message via AIM to coletrain
ooo, pretty valve cover, nice work so far
coletrain is offline   Reply With Quote
Old 07-09-2008, 03:20 PM   #12
lucid
ENGINE & PARTS:
Old 07-09-2008, 03:36 PM   #13
lucid
PORTING & POLISHING:
This was my first attempt at this, and I am pretty happy with the way things turned out.
Old 07-09-2008, 03:47 PM   #14
oranger
oranger may have said something they shouldn't have...
Wow clean, good looking, and that's not all I could say about it. I'm impressed by the build man. Keep it coming, can't wait to see you smoke some teggy's!
Proud owner of the only JJDM full 2.5" catback exhaust!
oranger is offline   Reply With Quote
Old 07-09-2008, 03:49 PM   #15
bigjoegood1
bigjoegood1 is cool... so far.
Send a message via AIM to bigjoegood1
"I'm a dude playing a dude, disguised as another dude"
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
Romans 10:9
bigjoegood1 is offline   Reply With Quote
Old 07-09-2008, 07:23 PM   #16
accordtypeR
Ohh okay..me likey...
My Old Baby
SOLD TO
Old 07-09-2008, 08:37 PM   #17
Law Grandeur
Law Grandeur seems to have made some friends! Law Grandeur seems to have made some friends!
Send a message via AIM to Law Grandeur
total sleeper! i love it!
no
Accord turbo kit under $2k here
$30 HID kits here Thread
"What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
"No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
Law Grandeur is offline   Reply With Quote
Old 07-10-2008, 12:22 AM   #18
kouzie
kouzie is cool... so far.
wow..........theres not much to said here.......
INTERIOR IS HOT!!!
kouzie is offline   Reply With Quote
Old 07-12-2008, 01:10 PM   #19
Shadow1
MidAtlantic Regional Mod
Shadow1 seems to have made some friends!
Send a message via Yahoo to Shadow1
nice man. hope to see you at future meets
Shadow1 is offline   Reply With Quote
Old 07-12-2008, 01:30 PM   #20
Jack_lee
Jack_lee is cool... so far.
i saw some plastic polished parts at the interior.....nice car indeed...
-My Member Ride thread-
-JL store-
Jack_lee is offline   Reply With Quote
