ok i have some 6.5 ma audio components and i need to cut some rings to mount them (not in my cb) but cutting them is a real pita. i tryed with a jig saw and burnt my jigg saw's motor out. tried a hack saw and came out with an oval, and i tried 5 times. i even tried to use a dremel and the caught the wood on fire. anyone got any good tips for me
best way to cut speaker rings?
Originally posted by bizzyboi View Postok i have some 6.5 ma audio components and i need to cut some rings to mount them (not in my cb) but cutting them is a real pita. i tryed with a jig saw and burnt my jigg saw's motor out. tried a hack saw and came out with an oval, and i tried 5 times. i even tried to use a dremel and the caught the wood on fire. anyone got any good tips for me
the problem i had was i needed a irregular cut board with a hole in it to fit my door panel (93 eldorado). so a ring by its self would not work as i still would have no place to mount it. and the bastards at the shop i bought my hu from wouldnt sell me anyLast edited by bizzyboi; 04-12-2009, 10:03 PM."Yeah. I'm a tough rich pimp with a gun, a fast enzo, and a huge dick. Don't fuck with me."
u can either use a router or a jig saw, i dont see how using a jig saw caused the motor to burn out? were you using the right jig saw blade?"Yeah. I'm a tough rich pimp with a gun, a fast enzo, and a huge dick. Don't fuck with me."
draw the diameter of the circle on your board. put a dot where the center of the circle is.
Tie a length of string the same length as the radius to a thumbtack and stick the tack in on the center mark, and tie the other end to the dremel...it won't be perfect, but that'll probably get you a pretty round cut.There are no black and white suspension answers!!!!!!!!!!!
Originally posted by bizzyboi View Postok i have some 6.5 ma audio components and i need to cut some rings to mount them (not in my cb) but cutting them is a real pita. i tryed with a jig saw and burnt my jigg saw's motor out. tried a hack saw and came out with an oval, and i tried 5 times. i even tried to use a dremel and the caught the wood on fire. anyone got any good tips for meLast edited by tgdrums1990; 04-12-2009, 11:29 PM.
