Hey folks. Over the past few months I have been working on custom 3 way speakers.
Since initial completion of the project it has now become a log of trying to make it as good as I could for minimal money.
The tweeters are Dayton ND20 push fit surface mount.
The mids are Tang Band W2-802SC.
The woofers are Jamo 6.5" 4 ohm drivers.
Update : 7/15/11
New Radio
Finally invested in a decent deck. Alpine CDA9813. Time Alighnment, Active 3way crossovers. The works.
Also nabbed a pair of Dayton Audio RS100 drivers at the Parts Express tent sale for 11$ These will be replacing my pods.
Bass is coverd by a Bosten G2 12. The 8" subwoofer is NO MORE, ripped surround.
VR3 2 channel 100watt max amp on the tweets.
Jensen 4 channel 600 watt max amp on doors and mids.
Directed D2400 on the sub.
Total system power is 1000watts ish rms under current configuration.
Ok on to the baffel. My gaol was to have a my box sealed into the cabin of the car isolating it from the trunk to prevent trunk vibrations and imo it really does add a certain level of cleaness that you cant get having your subs in your trunk. Also I wanted the box to be removable so that in the future I could go to a differnt sub or subs. So I built a baffel that the box bolts too.
Bottom
Top Left
Top Right
The Sub itself, Oh yea
And the Front of the box mounted in the car
Side shot of the amps
Top view ( Jensen is mids and woofers and the vr3 amp is for tweets and the Pyle Crossover is no longer installed since new deck upgrade )
The sub amp and some mis wires.
Current Configuration:
Tweets Are 4K 12 db slope
Mids are 200hz HP @ 12db slope and 3.5K @ 18db
Doors Are 90hz HP @12db and 200hz LP @ 12db
Subwoofer is 75hz @ 12db
There are still holes yet. I need to get some real midbass drivers for the doors.
Update 1/8/11
Well still not sure about what im gonna do for a midrange setup. I have become more critical of appearance and wanting to hide the speakers witch makes for a lot of work when try to hide those 4" beasts.
The Jensen amp will be comming out soon. I have a Memphis MCLASS 3004 to replace it.. Just need to add a second batt and upgrade my ground and alt wires...
Also today I orderd a TC Sounds EPIC 12 to replace my bosten g2 12..
Update : 7/15/11
New Radio
Bottom
Top Left
Top Right
Update 1/8/11
