The is everything you will need to convert you long throw, super high accord shifter to a smoother throw shorter shift lever prelude assembly.
*Get you hands on a 92-96 prelude shifter, plate console, and cables
1. Make sure your car is in neutral and remove the accord shif knob
2. remove the concole around the shifter, their should be 4 philip style screws holding it in place
3. disconnect the cables from the accord shifter
4. remove the 2 retainer clips that are holding the cables to the console
5. unscrew the 4 bolts that are keeping the shifter plate to the chasis( the plate should lift up with ease).
6. Pop the hood and locate the 2 cable that are attached to the tranny
7. remove the clips and take the cables off, the their will be 2 more retaining clips that will have to be removed so do so.
8. JACK the car up and make sure its secured with jackstands.
9. You will have to now drop you exhaust and remove the heat shielt.
10. their will be 2 10mm bolts that are holding the shifter cables in place, remove the two bolts
11. Slide the cables out carefully throw to the engine bay.
12. Now you will just install the prelude shifter plate where the origional accord assembly was installed. You will run the prelude cables the same why you removed the accord cables and do everything stated in reverse.
Good luck
Good luck
koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
New & Improved 93 Accord EX Coupe
