I noticed that there isn't alot of info on how much a swap would cost. I am compiling a list of my parts for my swap and thought I would share it so others can look and get a rough estimate on how much it might cost to do their swap. Mind you this is what I would "classify" as a middle to low cost swap.
As of now it will just be a swap, no mods as of yet. Keep in mind this is just something you can go off of to calculate how much it might cost you to swap. All areas of the country will vary in cost due to location and availability of parts at the time. For those looking to do the F22b swap I will also oblige in giving Honda part numbers for parts purchased through Honda.
JDM F22B DOHC long block - $650
H22 Auto Transmission - $400
JDM Si-R Accord TCU #28100-P0N-J01 - $80
JDM F22B Auto ECU #37820-P39-N51 - $100
H23/H22 USDM Distributor w/external coil - $65
Bisi moto intake manifold insulator gasket - $56
JDM F22B timing belt Honda part # 1440-PT2-004 and JDM F22B Balancer belt Honda part # 13405-PT0-004 - $98
NGK H23 spark plug wires part # RC-HE77 - $52
NGK G-Power H23 spark plugs part # ZFR6FGP - $11
F22Ax water pump Honda part # 19200-P0A-003 - $51
F22Ax thermostat Honda part # 19301-P08-316 - $13
F22Ax accessory belt w/ac Honda part # 38920-PT0-004 - $13
2x H23 cam oil seal Honda part # 91213-PT0-003 - $18
F22Ax balancer shaft seal/retainer kit Honda part # 06923-P0A-306 - $3
F22Ax rear main seal Honda part # 91214-PLE-003 - $13
F22Ax Fel-Pro oil pan gasket part # OS 30632 R - $25
Beck/Arnley H23 valve cover gasket - $42
Gates Power steering belt 14mm x 43 3/4" # K040430 - $19
F22Ax radiator hose Honda part # 19502-PT0-000 - $17
F22Ax radiator hose Honda part # 19501-PT0-000 - $11
Accord heater core hose Honda part # 79721-Sm1-010 - $7
4x Honda ATF Honda part # 08200-9001 - $21
2x Honda oil filters Honda part # 15400-PLM-A01 - $11
F22Ax Generic Ebay header - $80
2x Honda axle nuts Honda part # -
2x Honda cotter pins Honda part # -
2 gal Honda antifreeze Honda part # - $21
Labor for the install - $550
total so far = 2377
Now if you notice I haven't yet purchased a power steering belt, this is because I need a custom sized belt or get a bigger one because I will be retaining my F22Ax's ps pump. I also haven't added in the cost of fluids and such. I will edit this post as I get closer to finishing my swap.
Remember this is something you can base your swap cost on. I am doing my swap right the first time by changing a lot of the seals and gaskets and I advise anyone doing a swap to do like wise. It may seem like you're spending a lot up front, but I promise you it will save your ass in the long run.
total so far = 2377
