**FITMENT PICS ADDED**
Okay guys, I just recently swapped a Prelude type S cluster into my 1990 CB7, and I couldn't find a DIY when I was searching around, so here it is.
**WARNING: I've been told that the wiring is different on LX & DX and 92-93 models, so I'm not so sure if you want to try this. But will work fine with EX or EX-R.**
Also, this format was used from the following link, as I found it easy to comprehend, and it also provides the wiring for a Prelude cluster in a 5th gen accord:
http://board.accordtuner.com/showthread.php?p=454970
Accord................Function....................Prelude
__________________________________________________ ______
A1 (Blue).........................Tachometer......... ..............B5 Blue
A3 (Black).........................Ground............ ................See Note(1)
A4 (Yellow).........................Power............ .................See Note(2)
A6 (Orange)........Speed Sensor (Speedometer)..........B3 Blue/White
................................Odometer/Trip Circuit.....................................
A9 (Red)........................Dash Brightness...................See Note(3)
A10 (Red/Black)..........Guage Lights (Switch)..............See Note(3)
B6 (Red).....................Coolant Temp Guage..............C10 Yellow/Green
B9 (Black/White)....................Dome.................... .....See Note(4)
B10 (Green/Red)................Rt. Front door...................See Note(4)
B14 (Green/Red)...............Low Fuel Sensor...............C11 Lt. Green/Red
B15 (Yellow/White)...............Fuel Guage....................A12 Yellow/Blue
B19 (Green/Yellow).............Lt. Rear door....................See Note(4)
B20 (Green/Blue)................Lt. Front door...................See Note(4)
B21 (Green/Black).........Trunk Light/Latch Switch.........B12 Orange
B22 (Green/White)...............Rt.Rear door....................See Note(4)
C1 (Yellow/Red).............Oil Pressure Warning.............C7 Yellow/Red
C3 (Yellow)...............................Power...... .................See Note(2)
C4 (Red).........................Cruise Control Unit..............A11 Blue/Black
C6 (Red/Green)..........High Beam Indicator Light.........B1 Red/Yellow
C7 (Red/Blue).....................Lighting Switch................See Note(3)
C8 (Black/Yellow)..........Charge Warning Light.............B9 Black/Yellow
C9 (White/Blue)............Charge Warning Light..............C1 White/Blue
C10 (Green/Red).......................CEL.................... ........B16 Grey/Red
C11 (Green/Blue)..............L. Turn Signal......................A6 Green/Blue
C12 (Green/Yellow)...........R. Turn Signal......................A7 Green/Yellow
C13 (Black)............................Ground......... .................See Note(1)
C14 (Green/Red)...............Parking Brake......................A5 Green/Red
C15 (Blue/Red)...........ALB Control Unit (ABS)................C6 Blue/White
C16 (Red/Black)......Lighting Switch (Dimming)...............See Note(3)
And FOR THE AUTO GUYS...
B3 (Green/White)................Park........................ ....D6 Black/Blue
B1 (Green/Red)................Reverse....................... ......D5 White
B11 (Green)......................Neutral.............. ................D4 Red
B12 (Green/Black).................D4......................... .......D3 Yellow (NOT A POWER WIRE)
B13 (Green/Blue)..................D3......................... .......D2 Green
B16 (Green/Lt Yello)...............2............................ ......D1 Blue
B17 (Green/White).................1.......................... ......D16 Brown
Notes:
Note(1): All solid black wires are grounds, there should be 4 in all (2 from the accord cluster & 2 from the prelude) so just connect them all together.
Note(2): All solid yellow wires are power, should be 3 from each cluster to give 6 in total, and once again, just connect them all together.
Note(3): The solid red & red/black wires indicated all deal with the lighting. All of the solid reds go together, and all of the red/black wires go together.
Note(4) Since the prelude cluster does not indicate doors separately, all of the wires for the doors and the dome light are wired together
Conclusion & Ending notes:
So any left over wires can just be taped up, as there will be quite a few, so don't be scared...lol, especially for the M/T guys. If you're A/T by any chance and want to do the swap, just msg me & I'll go through the wiring diagrams and figure it out for you. As for the ALB, I believe that refers to the ABS, or at least that's what I was told, so if anyone knows otherwise, please let me know so that I can correct it. So that's that...any questions just PM me. CHEERS
Some day pics...
and at Night...
So here are the fitment pics. There is a little side gap, not really a big deal.
Cutout to allow cluster to go in further...
Rubber backing to protect back of cluster...
Cluster fitted...
Notes:
Some day pics...
and at Night...
Cluster fitted...
