Here is how to easily strip your trunk to save some weight.
I am not responsible for any... pain, broken bones, sneezing/sniffling, night time cough, insomnia, your stupidity, bad dreams, constipation, humping dogs, tumors, crying children, job loss, impotence, castration, death or anything else. You are doing all of this at your own risk!
You need:
Flat-head screwdrivers. Various sizes.
Metric Socket set.
Time.
If stripping tar, Dry Ice & gloves.
Upholstery tools work too. (10thcb7)
Ok, lets get started.
First start off with a clean trunk. Vacuum it if you want
Pull this and push your back seat down.
Run a screw driver under this "carpet pin" and pry it up. do so on the other side also.
lift the carpet to the top and start pulling the carpet off the clips on the top.
Pull the 3 pins out of the bottom so you have this.
These clips may be attached to the particle board so look for them. (mine weren't)
Pull the particle board and carpet out so you have this.
Ok now pull the cover off your jack storage and pull the jack out also pry up the carpet pin in there.
No Pic!
Pull the pin out of the wall of the trunk on the right.
Go back to your back seat and pull these pins out of the vinyl on each side.
Remove the vinyl covers.
Pull the pins out of the carpet attached to these braces.
Pull the walls to the side.
Go back to the trunk side and pull both of the carpet "walls" out.
You should have this. Stop here if you plan to put it all back in soon.
ADD! *Easy Abs light turn off!!!!*
ABS light on, but don't have the cash to get it fixed?
Simply take the 3 bolts out to get the computer bracket off. (2 at top 1 under relays).
and unplug the fucker!
It is ok to unplug this computer if your abs light is on, and you know you aren't going to fix it. If your abs light is on, you don't have abs braking anyway. This just makes it so you don't have to stare at that yellow light while driving.
[/ADD]
You need:
Metric Socket set.
Time.
No Pic!
[/ADD]
