Hi, today i cleaned my carpets and i decided to do a diy to show peoples every states of the cleaning , including the seats removing , i hope this will be useful.
You need a shop vac, cleaning product like hertel or other soap, cloths, a carpet cleaner ( i used turtle wax oxy power out), a rachet (wrench , i dont know the english term !) , flat screw drivers and a 14 mm wrench bit.
1: take off the 4 or 3 bolts caps to unscrew the seat.
be careful not to break this cap , it has a pin under it , i broke mine !
2: take the seat out of the car by the door.
3: enjoy how its dirty under the seat !
4: use the shop vac to eliminate the sand, chips, gums, cutip, and everything
5: Wash with normal soap , the 4 metal support where the seat bolt to eliminate the excessive rust or dirt.
6: Use the carpet cleaner and wash with a cloth has long has you can to eliminate the dirt ( i had rust on the carpet and after 10 minutes it disapeared ! ) so dont give up !
7: Do an other cleaning with the shop vac!
8: Lay on the back seat and enjoy the clean carpets.
