My otherwise perfectly functioning H22 Accord has started to give me signs of needing some attention soon. I think I have a sensor problem.
I noticed the first sign less than a month ago. Where there was none before, I now have a lot of carbon coming out of the tailpipe, and it's making the right side of my car noticeably dark from it since I haven't bathed her in a while.
I'm running rich, so I naturally suspect the O2 Sensor...It probably has 180-220k on it.
Then within the past week, the car (engine) doesn't accelerate from a stop when I try to go. I'll give it a little gas and let out on the clutch like normal, but it's like the car doesn't know I'm hitting the throttle. It will feel like there is no power, for less than a second, then instantly the power kicks in and the car accelerates normally.
I am expecting a sensor problem, but am wondering if the 02 sensor alone can cause both symptoms, or if it could be the TPS or MAP sensors too/instead.
I do not have an EGR, EVAP, or FITV system. The car is a 5-speed.
The Igniter chip, cap, rotor, plugs and wires are all new, (~20k).
The O2, MAP and TPS sensors, coil, dizzy itself, and alternator are all old and suspect.
I have a small stereo system that probably doesn't pull much more than about 10 amps (~130W), but I'm using an unknown-mileage junkyard alternator from an F22 at the moment.
I am away from home right now in NC, so I don't have any spare parts to swap with, but I do have most of my tools, including a multimeter.
I have spares of whatever part I need at home, from my other engines, except another dizzy.
For now I am going to clean up the ignition system (plugs/cap/rotor) just to be sure that stuff's good, but since the engine power is instant off-to-on I still suspect a sensor.
I do have my Factory Service and Haynes manuals here, and could check /adjust my TPS, but I set that perfectly when I built the motor. My idle is still fine, so it could be going bad, but I doubt it moved.
I may have a tiny vacuum leak on top of my S2 throttle body where I have just had tape covering the bolt-on MAP sensor hole (since ours are in the box on the firewall), I will fix that when I clean the ign. parts.
I probably wouldn't make a thread for this if I were home, I'd be in the garage playing swap-the-part.
But since I can't do that where I am now, I may as well ask for some brainstorming help. Any knowledgeable advice or suggestions are welcome. Maybe one of us is familiar with these symptoms. I'm sure whatever is happening to my car has happened to someone elses.
