Props to Keeledesign for creating this
Originally posted by KeeleDesign
View Post
Q) What color is my Car...?
A) If you open your driver's door and look to the right on the center post or *B* Pillar you will see your vehicle's color code...
Q) How Much Paint Will I need To Paint My Car...?
A) With a FULL paint-job including your jams you would be better off getting a gallon of paint and a gallon of clear just to be on the safe side and have some left over. However 2-3 quarts will shoot the whole car. ***BTW 4 Quarts = 1 gallon***
Keele: you did not tell them rather this amount of paint was reduced or not.. And to give a idea that all you will need is a gallon of reduced paint would be totally wrong.
Every color has different appaerent covering millage. and every Paint Brand brand does as well..
Rule of thumb is more expensive the paint the better it will cover with less coats.. [I]most the time[/I].. Their are paints like House of Kolor, it would take around 3 gallons of reduced paint to covere our car.. if you have extra pieces such as body kits.. it will take even more.
Q) What's the difference between a Two-Stage and Single Stage Paint Job..?
A) A Single stage Paint is cheaper quality. having the paint and clear mixed toghter allows for painting once and the job is done *Similar to some Earl-Scheib paint jobs*. A two-stage paint is Identical to your O.E.M paint. It has a Base Coat for the color, and a clear sprayed on top of it. Two stages are superior quality to ANY single stage because they offer better protection to the elements, look alot better in terms of quality, and more *Fixable* i.e buffing out scratches, blending the paint ect...
Keele: This statement is so wrong in every aspect.
A Single stage paint Job is one of the best in duribility and flexibilty.
It's easier to buff out gouges not just scratches. Because it will shine back up even if their is only 1 mil of material on their to work with.
A single stage isn't just paint added with clear.
It is a paint that has a single layer additive. this allows the paint to shine once sprayed on.. even with just one coat..
The right way in applying this,, is to add 2 coats of this on your vehicle, wait 8-10 min between coats if spraying in 70-80 degree conditions,
then mix this 1:1 with the clearcoat and making sure you use the same hardener that u put in your single stage, Because if you do not bad things will happen, such a cooking up or lifting. and put 1 coat of the half single stage and half clear on the car.
then mix 1part of whats left in your cup, whitch should not be a whole lot maybe a 4th of the 1.7 reduced pint cup,, with 2 parts of clear.
then you go with your final coat with straight clear.
and be sure to wait the 8-10 mintues between every coat.
This will give any solid color an amazingly deep look as compared to basecoat clear coat alone.
This is why Chip Foose's truck that was overhauled was single staged.
The idea that every car comes from the fACTORY WITH BASE COAT CLEAR COAT, IS HIGHLY MISPERCIEVED. sorry about the caps.
and it offers less protection from the elements,, but is ideal for any metalic colors, or pearls..
and when it comes to a 3 stage paint, where you lay your ground color then the pearl on top of that, it would also need to have bascoat clearcoat application
Q) What is Blending...?
A) Blending is when you spray paint on an adjacent panel to what ever your painting however you only lay the Base coat or Color a few inches in. Then you clear coat the entire panel. For example is you change your fender and it's a different color you need to paint it, however the new paint might not perfectly match you old door so you would want to "blend" the new paint into the old door. This tricks your eye into seeing the repair as a whole instead of looking a one piece that's extremly shinny and abit off in color.
Keele: most the time your blend should cover 3/4 of the panel you are going onto. and you should have all the blending agents to help keep everything seemsless.
Q) How many coats of clear do I need for the best paint..?
A) Many people will probally argue about this cuz there is a ton of mis-information floating around. But, I always read magazines and get a good laugh. My car has 12 coats of clear and looks great...
The most coats of clear I would reccomend would be 3 or 4. You can however put much clear you want. When you buff it out you'll see why it's not good to add too many Layers to your paint.. It's not the Quanity as much as the QUALITY! 10 coats of cheap clear does nothing for your perfect paint, however 3-4 coats of the good stuff *Du-Pont, PPg* will give you a great finish that will last 10 + Years...
Keele: What!!!are you crazzy....
Just look at the clear you buy, it will tell you the best coat coverage that is needed.
Most clears are not designed for more than 2 coats. The more clear you add the more of a chance it will fail...
Metal and plastic flex and contract in heat and cold all the time,, this will make the clear crack or peel or crowsfoot, or become verry dull looking compared to the virant color that was laid underneith.
I paint cars daily and as of date i have painted over 30,000 cars,
that includes many hot rods and custome show vehicles. the most we have ever cleared is 3-4 coats,, and thats with either house of Kolor or Nexa's 643 clear.
Their is no arguement with this.. their is a right way and a wrong way of doing things.
Extra clear doesn't make a paint job slicker, it actually makes it look shittier. By putting to much clear a cars slick surface will start to become all ripply and chunky looking,, even if you wetsand and buff it, the most that is taken off by doing that is around a half a mill.. that will not slick out the rough clear..
That much clear will also build up around every edge and making it much easier to chip because of that.
If you want you can paint and clear a vehicle, then allow it to dry completely, and rewetsand it and reclear it with 2-3 coats again.. and that is acceptable and will turn out great.
Q) I want a custom paint job. How much will it cost...?
A) It depends on too many things to actually answer this question. Ask yourself what do you want out of it..? Perfection..? It's always better to do it the right way the first time BUT, not always praticle. Do you want to remove your, windows, trim, door handles, interior, parts in the engine compartment ect..? Just so you don't have tape lines...? Or do you just want to mask everything off...? Do you care if down the road your paint starts cracking..? or do you want it to last forever. Bottom-Line is The more you understand the paint process the better equiped YOU are to make that decesion and find out what best suits you and your budget.
