While I was redoing my suspension last week, I decided to remove and "blackhouse" the headlights real quick.
I got the lights open and was showing a friend what I was up to, but they know me well and gave me shit for not going ahead with a retrofit when I have projectors I can use. I will still do a black-out on everything but the high beam reflector dish before reassembly.
So now I'm doing a full (halogen) projector retrofit, using JDM integra TypeR 9006 projectors. I got them from a set of real JDM DC TypeR one-piece headlights I picked up at a junkyard for $20.
Wish they were the HID ones, and the cutoff's on the wrong side since it's JDM, but I'll either modify it or just not worry about it (like everyone else with real Japanese market headlights). I plan on buying a 9006 HID "Kit" once these are done. I've got a set of Porsche HI/LO combo projectors, but this is my first retrofit, being cheap, and I'm saving those for another project.
I did not realize before I got started just how large the Integra's projectors are.
I have to grind the housing down so close on the top and bottom of the projector body that I am shaving off the screws that hold the front and back of the projector body together.
Fortunately it didn't take much modification to use the back of the existing holes for the lens bezel.
I thought carving out the stock 9006 bulb holder hole would let me slide the projector housing right in,
but the Accord's bulb hole isn't actually in the center (top-to-bottom) of the housing. The projector sits a little crooked as is, pointed slightly up since the hole in the back is slightly low. I'll be slotting the hole in an upward direction to allow the projector to center, but things still look promising.
This is not a spare set of headlights, and I can't drive my freshly lowered car until I'm done, so I'll be finishing this as soon as I can manage. I'm only working on the passenger side headlight first. Today I bought a 3-foot section of 1/4" threaded rod and hex nuts in Stainless Steel for mounting the housings together. . . and some fresh JB-Weld.
I plan on slotting the hole in the back of the housing to allow the back of the projector assembly to pass thru and still point straight.
Any suggestions are welcome, guys
