Does anyone here know where I can get Halo Projectors for my 93 Accord EX?
Halo projectors for 93 accord
They don't make halo projectors for the 4th gen Accord, you would have to make some your self.Adam - Retired OG member from '03
HIB? or HID? HID yes if you have either a kit or use rebased OEM D2S bulbs...but I dunno what HIB is...guess I have been out of the loop on the whole lighting thing."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
http://www.cb7tuner.com/vbb/showthre...10#post2119010
I know I know!!!
HID = High Intensity Discharge "Any system that has ballasts to ignite low energy using high performance bulbs"
This does not include systems such as CatZ Zeta Kits which just amplify a bulbs brightness
HIB = High Intensity Bulbs This includes PIAAS or any colored glass & xenon gas filled bulbs to mimic Hight Intensity Light. So far Silverstar bulbs ($39-$50 Depending on application) are as close as you can get to HID without buying a expensive HID system.
If you want to go even more expensive, you can get Japanese PIAA or Raybrig bulbs. These range from $60 - $160 for one set. Expensive but outperform even Silverstars.
Props to the NB and welcome to the board!I need a custom turbo manifold built....
707 NorCal NinjaZ
Honda Twincam Motorwerkz?"I am the Yakuza CB7!"'92 Accord Sedan SiR
its funny, i have all the things to make the halos for my headlights but i never got around to do them...i even did the halos and all.
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
Originally posted by onelove4everyon
Sorry I meant HID bulbs!!! Oh, is there a way to make the halos? is there a kit somewhere or is it a custom job?
