DSM injector seals keep leaking
    so last week i replaced two sets of seals/o-rings on my injectors cuz 2 of them were leaking. i replaced the larger rubber seals on the bottom of the injector that are placed in the IM, as well as the tiny ones on the top of the injectors that seal into the fuel rail. i replaced all 8 of them.
    now today another one started leaking again... WTFFF!!!!
    on the bottom of the injector there's supposed to be a plastic o-ring that's under the rubber ones and i took all of them out cuz i read to do so w/ the DSM's. and i also bored out the rubber ones with a dremel so the DSM' could fit, so the injectors seal very very snuggly into them.
    how is everyone else doing it? leaving the plastic seal in there??
    wtfff
    BB2F22-T3super60:250hp/275lb-ft @10psi
    i dont know how everyone else is doing it but all i did was remove the hard seal and i didnt modify the rubber seals. but i am using evo9 injectors wich i think are the same other than the cc's. it is really tight but no leaks yet.
    278 whp 266 wtq.
    build thread. CLICK HERE
    http://www.cb7tuner.com/vbb/showthread.php?t=126819
      I USED to dremmel out the injector bushings, but I found that to be unessicary. When I do injector upgrades, i just put new bushings and o rings on, and make sure I lubricate them with grease/assembly lube/petrolium jelly, install the injectors into the fuel rail first, slowly and gently push them in... make sure none of the o-ring is getting caught up and pinched off when you put them in.
      Then put the injectors/fuel rail on, push down a little till you can get the nuts started, and tighten the nuts down on the rail. you should be good from there.
      -Big3racing.net-
      My Build Thread. Many pics.
        NO DREMELING OR MODIFICATION NEEDED!
        keep all your seals.
        on the lower ones for around the injector just lube up the outside of the injector with oil or something and just slip them in.
        very simple, no modification or dremel required for DSM injectors!
        MadLab Racing
        Southern Maryland
          guess i'm ordering 4 more, haha
          thx guys
          o, and i should put the plastic ones back in???
            I found it easiest to use the dremel on the hard plastic piece to make the boar ever so slightly bigger.
            spin city
              No Danny, you don't need to do that.
              Mine slid right in wthout any modification.
              Joser helped.
              MadLab Racing
              Southern Maryland
                aight i just put the new seals in the way hondabob described, and put the plastic seals in as well and they already LOOK like they'll seal 1000000 times better than the previous way.
                tnx guys!
                  good deal...
                  and no leaks I take it?
                  MadLab Racing
                  Southern Maryland
