Ok fellas, I decided to create My MR page. This is how she sits now.
Cappuccino #16
When I first got it:
It has come a long way. I purchased this car back in October ’08 for $1200 from a friend who was not interested into the car at all. I personally was looking for a Civic Hatch but my attention was drawn to this car. I was a little disappointed that it was an automatic but it looked pretty clean and had 93,000 miles on the ticker. At first he told me that it needed rotors in the front and that’s it. Well that wasn’t all that was wrong with it! LOL!! I started to give up on the car until I ran across this web site. You guys gave me very good information and inspired me to transform my project into a reality. Much respect to all of you!!!! Here is my list of things that has been done.
ENGINE, EXHAUST & PERFORMANCE
1. F22 A1 SOHC 93,000 miles
2. NGK spark plugs
3. New OEM main relay
4. New OEM dizzy, cap, rotor, wires
5. New OEM radiator
7. New OEM water pump
8. New OEM thermo
9. New OEM speed sensor
10. New OEM valve cover gasket
11. New OEM EGR valve
12. New OEM cooling fans
13. New heavy duty upper radiator hose
14. Cleaned and tighten FTIV valve
15. Cleaned IAC valve (^both cleared my idle problem!)
16. Fixed vacuum leak
17. E bay short ram intake
18. P12 auto ECU (DIY manual conversion very important!)
19. Greddy oil filter adapter (quick way to add oil pressure gauges)
20. E bay headers
21. 2.5in piping all the way back
22. New cat
23. 18” resonator
24. Greddy Evo 2 muffler (sounds very good!)
25. AC delete
26. Cruise delete
AUTO TO MANUAL 5 spd. SWAP!!! (THE HARD WAY!)
27. DIY auto mounting bracket removal and 5spd bracket weld
28. F22 manual transmission
29. Fidanza flywheel
30. Exedy stage 1 clutch
31. All items for swap!
32. New OEM 5spd trans mount
33. New OEM Honda throw out bearing
34. New OEM 5 spd starter
35. New OEM clutch master cylinder
36. New OEM slave cylinder
37. New OEM 5spd axle
BRAKES, TIRES & SUSPENSION
38. New OEM rotors
39. New OEM calipers
40. New OEM brake master cylinder
41. 15in. 10th anniversary Honda rims on 195 65R 15 Falken tires (winter)
42. 17in. Konig Tantrum rims on 215 45 ZR17 Bridgestone Potenza tires (summer)
43. Premium wheel locks & fasteners
44. Skunk2 adjustable coil overs
45. Tokico HP (blues) Shocks
46. 1.75in drop (front) 1.5in drop (rear)
EXTERIOR
47. OEM fog lights
48. New OEM corner lamps
49. APC side markers *REMOVED* Saab sidemarkers *INSTALLED*
50. 90-91 red clear tail lamps
51. 90-91 rear mud flaps
52. Acura Legend sedan lip
53. Wal-Mart rubber antenna
54. E bay window visors
55. BMW flush mount spoiler *REMOVED*
56. DIY black housed head lamps
57. DIY black bumper & molding trim
58. DIY black emblems
59. DIY black drums & calipers
60. DIY black grille
INTERIOR
61. 3 Glow Shift 52mm gauges. Vacuum, Air/Fuel Ratio, Oil Pressure
62. E bay sports steering wheel with DIY Honda “H” emblem on horn
63. DIY chrome trim around factory gauges
64. Auto zone pilot racing pedals
65. Integra DA tan cloth headrests
66. LX arm rest
67. New OEM shift boot & shift knob
68. New OEM Auto seat belts
69. DIY short shifter
70. Tan 6X9 pod swap
71. AC control unit replaced
72. Master window switch replaced
73. Factory temp gauge replaced
STEREO SYSTEM & OTHER ELECTRONICS
74. Power Accustiks mobile video system with removable 7in monitor
75. MTX x704 4 channel amp 420W
76. POP’S 400W 6X9’s (made in the Chi Town area. Very heavy duty!)
77. POP’S 400W 6 ½ in the doors
78. MB Quartz tweeters *REMOVED* Pioneer 120W tweeters *INSTALLED*
79. Zune 30gig MP3 player
80. Cobra 360 radar/laser detector
81. IC Dynamics alarm remote start & 2 way pager system
FUTURE PLANS
New ball joints
Energy suspension bushings
Camber kit
Rear disc conversion
OEM Honda hood bra *INSTALLED*
5000K H.I.D. kit including fogs
215 45 ZR 17 tires *INSTALLED*
Find OEM flush mount
Black 5 star rims with polished lip
1 piece JDM black housed head lamps
Different suspension setup
Here are a few random pics I took along the journey: Enjoy! Please leave feedback!
Rollin with a few fellow members from the Mid West!
Cappuccino #16
2. NGK spark plugs
5. New OEM radiator
8. New OEM thermo
20. E bay headers
22. New cat
23. 18” resonator
25. AC delete
26. Cruise delete
38. New OEM rotors
EXTERIOR
47. OEM fog lights
INTERIOR
66. LX arm rest
FUTURE PLANS
New ball joints
Camber kit
Clean cappuccino!
LOL! But in the end you will be suprised on how everything is going to flow.
