Feel free to post up pictures of different setups. State your spring/shock combo, or coilovers, and tire size IF different from stock overall diameter.
Also, feel free to discuss about how a given setup rides/handles, just don't get off topic.
**Rates are in lbs/in...to convert to kg/mm divide by 56 (this is a very close approximation)**
What are compression(aka bump) and rebound, and what do they mean to me?
(Taken from a Koni USA SCCA presentation)
Rebound:
Compression:
LOWERING SPRINGS
Stock CB7 Springs: 220F, 150R (0.0"F, 0.0"R)
Neuspeed SofSport: (0.75"F, 0.75"R) rates unknown
Neuspeed Sport: 260F, 165R (1.75"F, 1.5"R)
Neuspeed Race: 485F, 300R (2.2"F, 2.0"R)
Sprint Whatever: (1.5"F, 1.5"R) 25% stiffer than stock
Sprint Blues: (2.25"F, 2.25"R) 15-20% stiffer than stock
Sprint Extreme: (3.25"F, 3.0"R) rates unknown
H&R OE Sport: (0.75"F, 0.75"R) rates unknown
H&R Sport: (1.75"F, 1.5"R) rates unknown
H&R Race: 485F, 305R (2.2"F, 2.0"R)
Eibach Pro Kit: 331F, 228R(progressive rear only) (1.2"F, 1.2"R)
Eibach Sportline: 331F, 228R(progressive rear only) (1.8"F, 1.7"R)
Megan Racing: 280F, 250R (2.0"F, 1.75"R)
Tein H-Tech: 220F, 150R (1.5"F, 1.1"R)
Tein S-Tech: 250F, 160R (2.1"F, 1.7"R)
Skunk2: (2.0"F, 1.8"R)
Tanabe DF210: (2.0"F, 2.0"R) 10-15% stiffer than stock
Tanabe GF210: (1.2"F, 1.2"R) 20-30% stiffer than stock
Tanabe NF210: (1.8"F, 1.5"R) 0-5% stiffer than stock
Tenzo-R: (2.25"F, 2.25"R) rates unknown
Matrix: (2.5"F, 2.25"R) rates unknown
Progress Sport: 300F, 185R (2.0"F, 2.0"R)
Suspension Techniques Sporttech: (1.0"F, 1.0"R) rates unknown
Suspension Techniques Speedtech: (2.0"F, 1.8"R) rates unknown
RS*R Down Springs: 285F, 156R (1.6"F, 1.0"R)
B&G Sport Springs: (1.6"F, 1.6"R) rates unknown
Dropzone: (2.25"F, 2.25"R) rates unknown
Maxspeed: (1.75"F, 1.5"R) rates unknown
Vogtland: (1.6"F, 1.6"R) rates unknown
Tokico HP: (1.25"F, 1.25"R) rates unknown
D2 Racing: 236F, 168R (2.25"F, 2.25"R)
FULL COILOVERS
Tein Basic: 336F, 280R (3.4"F, 2.6"R) Damping adjustable: No
Tein SS: 336F, 280R (3.3"F, 2.5"R) Damping adjustable: ?
Tein SS-P: 336F, 280R (3.3"F, 2.5"R) Damping adjustable: ?
Function & Form Autolife Type 1: 672F, 336R Damping adjustable: No
Function & Form Autolife Type 2: 672F, 336R Damping adjustable: Yes
D2 Racing RS: 678F, 398R Damping adjustable: Yes
Ksport Kontrol Pro: 560F, 336R Damping adjustable: Yes
Megan Racing Street Series: 784F, 336R Damping adjustable: Yes
Megan Racing EZ-Street Series: 672F, 280R Damping adjustable: Yes
AMR Engineering: Custom made, purpose built; Damping adjustable: Yes
H&R Street Performance: (2.7"F, 2.0"R) Damping adjustable: No
KW Variant 2: (2.9"F, 2.1"R) Damping adjustable: Yes
Blackworks Racing SS: 560F, 336R Damping adjustable: No
BC Racing: 560F, 336R Damping adjustable: Yes
DAMPERS
KYB GR2: Damping adjustable: NO
KYB AGX: Damping adjustable: YES, 8-way on car
Tokico HP: Damping adjustable: NO
Estimated damping force: 235F, 180R
Tokico Illumina: Damping adjustable: YES, 5-way on car
Koni STR.T: Damping adjustable: NO
Front: 670 compression fixed, 3150 rebound fixed
Rear: 310 compression fixed, 760 rebound fixed
Koni Red: Damping adjustable: YES, linear valve off-car
Koni Sport: Damping adjustable: YES, linear valve on-car, rebound only **features 3 height adjustment perches**
Front: 169 fixed compression, 674 rebound on full soft, approximately 1348 on full stiff
Rear: 67 fixed compression, 214 rebound on full soft, approximately 428 on full stiff
**numbers are at a velocity of 4.13inches/second**
Koni SP3: Damping adjustable: YES, linear valve on-car, rebound only **Same as Koni sport(yellow) but with 5 ride height perches and 20mm shorter droop length**
Damping is same as regular Koni sports above.
Bilstein HD: Damping adjustability: NO
Front: 440 fixed compression, 650 rebound
Rear: 995 fixed compression, 740 rebound
Interesting links/food for thought:
http://www.koni-na.com/presentations/SCCA/
http://www.koni-na.com/presentations/mustang/
http://www.koni-na.com/presentations/civic/
http://farnorthracing.com/autocross_secrets.html
Rebound:
- Controls "sprung" weight aka the weight of the car held by the suspension
- Affects transitional control
- Controls spring and chassis oscillation
- Balances understeer and oversteer
- Add rebound to "loosen" an end, remove rebound to "stick" an end
Compression:
- Controls "unsprung weight" i.e. wheels, brakes, etc.
- Holds tire to the ground
- Increase to improve grip and turn-in
- Affects ride harshness
- Generally increase until car begins to "skate"
LOWERING SPRINGS
FULL COILOVERS
DAMPERS
