So, a few things happened to the accord lately, i decided to put it in the garage, and work on it a bit. I had some issues with my catch can, so i removed it. I had fouled plugs (TOTALLY WHITE TIPS!) So im now running lean. The valve cover was leaking in the tubes (fixed). Now, ive got NO lower end power, None what-soever. It jerks a bit, Then when you hit around 2K, its ALL There.
Someone told me "this is all EGR related man, block it off, call it a day" So i did that, And low and behold, no hesitation. Replaced the EGR with one that does NOT leak at all, Same shit. So, i put my old EGR on, Seafoamed the intake manifold (with my old plugs of course), and cleaned the living shit out of it. Put in my new plugs, slapped on my working EGR, and the bugger still has no power on the low end.
its a f22A1, Vibrant cat converter (high flow), Warm air intake, and an exhaust header. The O2 is at the V pipe where it connects (extended the o2 sensor wires to reach to the bottom)
I have NO error codes, and judging by the plugs that i pulled out of the car a week after doing a seafoam, they are White as hell. So now im being told, im running lean, real lean... My o2 sensor is an NTK one, i bought it about 2 years ago, so i dunno when i should change it. I am able to get a Denso one from work for 88 CAD$, and i know to stay away from Bosch.. But seriously.. what else could be wrong with it?
I know its a 1990, but the plugs showing that it runs really lean, is a sign that somehting is really wrong.
What else can i look for?
If you need any more info, lemme know, i'll get it for ya.
-Dan
-Dan
