Alright, easy DYI but repairing this easily damaged mesh on your speaker will make it look mint.
Tools:
Phillips Screwdriver
Some kind of Spray Adhesive (I used Elmers, very good)
EST Time: 20 mins per door
1. Pull off the door panel.
2. Remove the speaker cover (2 screws on top of cover and 2 on the side)
3. Remove the speaker mesh from the cover. It should come off fairly easy.
4. Spray the cover (NOT THE MESH) all over with the adhesive (especially sides of it)
5. Adhere mesh to the cover. Do this as quickly as possible so you have the most time to reposition the mesh until it is well fitted.
6. Take the adhesive and spray inside the cover and take outside fringes of the mesh and stick it to it.
7. Put everything back together.
Its my first DYI so lemme know how it was
Thanks and good luck.
Tools:
