coolant deposit
    coolant deposit
    I got my car one month ago and the radiator was leaking so i change it and the coolant too.(diden't flush the block)
    Now i changed the thermostat tonite cause it was shot and discovered these deposits inside the t-stat housing:
    My coolant is very dirty too(the bottom of the container had a gray tint)and inside the block/rad i could see some white tint coolant.There is no sign of oil in the coolant,and my engine oil is fine,so i'm wondering what it could have done this and if it could block my heater core.
    I wan't to know some advice on the next step.Should i rince the system with water(i read that it is not good to put clear water)and refill with fresh coolant or buy a radiator rinse?Any brand i should look for?
    I made a search and all i found was head gasket issues,nothing about deposits like these.
    Thanks in advance!
    did someone run some sort of leak stop in your radiator?
    Do some serious flushing man...until you get ALL clear. then replace with 50/50 mix (mix yourself...the pre-mixed is a rip off)
    ____
      It could definatly be stop leak that someone put inthere to try and fix the radiator. A coolant flush couldnt hurt then just fill it with a 5050 mix.
      My CB7 http://www.cb7tuner.com/vbb/showthre...hlight=phalpin
        Looks like a piece of chewed gum... i would have to agree with everyone else, someone probably ran stopleak to fix the radiator problem. Flush your cooling system well, and refill with a 50/50 mix of water/antifreeze.
