Well here it finally is, I've been working on this engine and all the other external parts for the last couple years. I don't have a deadline. Its just a side project. I will update as I feel like.
Lets start it off with whats done to the engine.
Head:
JG Engine Dymanics ported head
Ferrea Dual valve springs
Ferrea Retainers
Ferrea Valve locks
KMS Stainless steel valves
OEM Valve seals
New bronze guides
Stock cam
Block:
F22A1 Block
Golden eagle sleeved
ARP Main Studs
ARP Headstuds
OEM Headgasket
Wiseco Pistons 8.8 CR 85.5MM
Carrillo Steel A beam rods
ACL Bearings
Aligned honed
Balance shafts eliminated
Engine externals:
AEM Fuel Rail
Aeromotive FRP
Precision 880cc Injectors
OBX Ramhorn manifold
Garrett Custom turbo
3" Downpipe to 3" Full exhaust
Action Clutch 2ms
ACT 11LB Flywheel
Gearspeed h22 transmission with Quaife lsd
Filled motor mounts
Custom Intercooler charge piping
RX7 Backdoor intercooler
Civic Halfsize Radiator
Electric Powersteering
Here are some pics of it in the car. Some things have been cleaned up. And there are a few changes to whats in the pictures as of the present.
Head:
Ferrea Retainers
Ferrea Valve locks
OEM Valve seals
New bronze guides
Stock cam
Block:
F22A1 Block
ARP Main Studs
ARP Headstuds
OEM Headgasket
ACL Bearings
Aligned honed
Engine externals:
AEM Fuel Rail
Aeromotive FRP
Action Clutch 2ms
ACT 11LB Flywheel
Filled motor mounts
