If your a practical person and don't mind hacking a hole in your trunk please read on.
After dropping the tank and stripping rusted bolts and fuel line clamps on a 1995 Accord,
I decided "F**k this s**t, if I ever I have to change a fuel pump, I'm doing it the easy way."
My 1990 has 220,000 miles on an original pump, so the day may come soon...
Lets begin.
Now ask yourself, do I really want to hack a hole in this virgin metal?
Why didn't Honda put an access spot on all cb7s?
Lazy designers? Integrity of the unibody?
We may never know...
Now that you have chosen to not to be a chump and cut a damn hole, these are the tools you will need:
Dremel
Cutting wheels (6 bucks at Ace)
Safety Goggles
Mini hack-saw (optional)
Now try not to cut too deep, you could start a fire with all those sparks if you cut a fuel line. Don't nick the wire harness either.
If you didn't win the Darwin awards and blow yourself up, you should have a decent hole.
Follow my measurements below.
If you're careless, you will probably end up with a jagged hole like mine.
A little deburring, dust busting, and wiping is in order.
Bunch of 10mm bolts, banjo bolt, wire harness connector, and some other stuff disconnected and you should have your fuel pump out painlessly.
Cover up that nasty hole with tarp, duct tape, or a true professional would fab up an access cover lol.
Lets begin.
Dremel
Safety Goggles
