Hey,
Ok. Could someone try to explain this a little better? I know the idea is to tell the computer that the car is in "park" to get the car started (but i thought the manual ECU would solve this, not accord to steve@HMO), as well as get the reverse lights to work. I'm having a tough time visualizing these process. Does anyone have any more information? Pictures would be great if avail.
Thanks
At this time you can do the necessary wiring changes. Cut open the transmission wiring harness. Cut off both counter shaft speed sensor connectors, the torque lock-up connector, and up/down shift connector. Leave the torque lock-up wires (yellow and green/black) exposed and re-tape the harness. These wires will be hooked up to the reverse light switch on the transmission later. In the passenger side kick panel, seperate the red/white and white/black wires from the connector that went to the Transmission Control Module. Extend these wires to the auto shifter harness and hook them to the yellow and green/black wires. Connect the red/white wire to the yellow and the white/black wire to the green/black for the reverse lights. Re-install passenger side kick panel. Unplug both clutch switch connectors from the assembly. Connect both solid black wires together, extend them and connect to the black wire in the shifter harness. Extend the black/pink wire and connect to the pink wire in the shifter harness. Extend the black/green wire to the shifter harness and install a female spade connector to the end of it. Connect this wire to terminal 86 on a 30amp relay. Cut the connector off of the big black/white and black/red wires that are beside the shifter harness. Install a female spade to the end of the black/red wire and hook it to terminal 87 on the relay. Install a female spade to the end of the black/white wire and add a 6 inch section of wire in with it. Connect the black/white wire to terminal 30 on the relay. Install a female spade on the 6 inch section of wire and connect to terminal 85 on the relay. While you have the passenger side disasembled remove the cover plate for the ECU and unbolt and change to the manual ECU, this is straight forward, everything plugs in just as it came out.
Thanks
my friends car still has no reverse lights
WiredMotorSports
