i've always liked how the prelude's hand brake and boot matched the shifter and its boot so i picked up a prelude assembly and had at it.
disclaimer:
this is for informational purposes only. i am not responsible for any damage or injury you or your vehicle may incur. remember: safety first!
tools:
-oven
-dremel (or other cutting tool)
-box cutter
-marker
-adhesive (i used a loctite vinyl adhesive)
-work gloves (very helpful)
-spray degreaser
-general purpose grease
-duct tape (optional)
parts:
-prelude hand brake and boot
-accord hand brake
**this is written assuming you already have the hand brake assembly uninstalled from the car or are capable of doing so**
-i already had an accord hand brake from the burgundy interior i swapped out. here's the side by side comparison with the prelude on the right, of course.
-set your oven to 225 degrees. place one assembly in the oven for 5 minutes then (with your gloves on) remove it and twist at the boot until it has completely come free of the assembly and slide off. repeat for the other one
-this is also a good time to replace the chipping brake handle button if necessary. the gloves also help with unscrewing these.
-with the prelude cover over the accord assembly it's obvious some modification is necessary.
-because the prelude cover curves and the accord assembly is straight, some cutting to both pieces will be needed. mark off the two to accommodate. the rear end of the assembly must be trimmed as well to fit the prelude boot. (be aware of the moving parts and how they interact with one another. before cutting, engage and disengage the assembly fully to ensure your cuts will not damage anything)
-use your cutting tool to cut away at the marked areas and test fit.
-once you have properly fit everything to your satisfaction, spray down the assembly with degreaser to clean out all the metal shavings and regrease the moving parts. i took an additional step to cover all the trimmed areas with gorilla tape so as to protect the inside of the boot.
-one thin line of adhesive on the top and one on each side then slide the handle onto the assembly. be sure it is sitting straight on the assembly. once it's set, pull the boot over the handle cover. you're ready to reinstall your newly upgraded hand brake!
-enjoy!
if you thought our accords were throwbacks, i noticed that the dremel my dad handed down to me is 10 years older than i am, bought on may 9th, 1972! i've been using this thing forever!
well there it is, my first DIY for you guys! i searched to see if anyone had done this, and so far i hadn't seen it. it's not monumental nor performance enhancing by any means, but it really helps to accent the interior!
disclaimer:
tools:
-oven
-box cutter
-marker
-spray degreaser
parts:
-accord hand brake
-enjoy!
