it took me a while to do this but as promised here it is:
before 90-91 tail lights
after 92-93 tail lights (same trunk)
I'll take you step by step as to what i did to make my trunk universal to all cb tail lights.
step one
go to the junk yard and buy this
its the middle part of a 92 93 trunk and you will definitely need it
step two
remove your trunk lights by taking of the 4 caps on each light as seen here
step 3 (you will need a drill)
you will need to drill 3 holes on each side to make the trunk lights fit.
once you drill the holes the trunk lights should pop right in but you will have a bunch of extra space because the 90 91 trunk lights are longer
now remove the lights.
step 5 grab the inner part of the trunk that you got from the junk yard
and pop it in
its gonna easily fit but to keep it on you will have to drill 1 hole on each side for screws.
once everything is nice and tightly secure put the lights back on and this time it will look like this
the license plate will actually help that thing stay on.
ALSO, notice that you will no longer be able to open your trunk with your key because it is now hidden.
screw your lights back on, make sure everything is tight and you should be ready to go
step one
step two
and pop it in
My MRT
water tights? there is already holes behind your tail lights, drilling other holes wont make water go in if water wasn't going in in the first place.
