Swappable Interiors...
    My seats need replacing...
    What's direct swap seat wise for our interiors?
    vigor? legend?
    1990 Honda Accord Sedan
    1998 'Slammed' Ford Crown Victoria LX
    The only seats that are a direct swap in a cb7 are seats from a 94-97 accord or 97-99 acura CL
    Here are acura CL seats for refrence
    All 4 bolts line up perfect
      perfect.. rear seats as well?
        no not rear seats, not for the coupe atleast
          The CL seats is a direct swap only for coupes. I have a sedan with black CL leather seats. On the passenger side only the left front and left rear holes lined up. On the driver's side only the front 2 holes lined up.
          1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
          2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
            hmmm so... anyone have a positive answer? lol
              Not without motification as acura CL rear seats do not fold down where as cb7 seats do. You can just get OEM cb7 rear leather seats though
              Im pretty sure coupe seats fit a sedan and vise versa so i don't see why you had a problem.
                true - just wanting to know my options when i go into the yard...
                see alot of vigors and legends vs cl's and cb7's with leather interiors
                good to know...
                  vigors are not a direct fit
                  legends are not a direct fit either
                  If you get a legend or acura CL seat you will guarantee having to wire the power seat up. If you find a legend LS you will also have to wire the passenger seat up
                  Vigors come without power seats, if you find one with it i would junk the rails. The power seat on a vigor is 4 day power ( forward/back and reclining ) so whats the point without height adjustment?
                    i have acura CL rear leather in my coupe and it was almost direct fit. bottom bolted right up top i had to remove the folding seat hardwear and drill some slits for the acura seat metal loops to sit in and drill those slits perfect size the seat wont even move.. mines solid in there check my MT for pictures or my" leather finally" thread.
                    #3MR 91 coupe: http://www.cb7tuner.com/vbb/showthread.php?t=186456
                    #2MR 90 sedan: http://www.cb7tuner.com/vbb/showthre...51#post2867651
                    #1MR 93 coupe: http://www.cb7tuner.com/vbb/showthread.php?t=176343
                      Vigor front seats with the rails it came with WILL NOT WORK. You CAN however, remove the vigor seat rails and replace them with some accord seat rails, which bolt up perfectly to the bottom seat cushion and the upper seat (analyze how you take apart the seat rails, and the installation is reverse of removal). If you've got time at the junkyard to take apart the seats and replace the rails at the yard, you can save yourself some money by not having to buy two separate things: the seat, and the accord seat rails.
                      good luck! I don't know much about sedan rear seats though
                      and, if you do have time, give the vigor rear seats a shot, try em out on a cb out in the junkyard... i THOUGHT it could work. never had the patience to try though, since i'm always pressed for time in the yard.
