I figured since I don't see any DIY for the H22 Euro R IM and decided that I'll go ahead and do one. This DIY will also give those of you who are unsure an idea how things will look like and what will be needed and what not to make this installation a breeze. I bought this whole Euro R IM kit from Roskoracing.com. It comes with everything you need to make it work.
**NOTE**: This Euro R IM has been modified to be slap onto the H22 head with no problem. An unmodified version from Hmotors or from any other place besides Roskoracing will need to be worked on before it can sit flush against the H22 head.
Tools Needed:
-3/8 Ratchet
-Sockets; 10mm, 12mm, 14mm
-10mm & 12mm combination wrench
-3/8 extensions
-Pry Bar
-Philips & Flat Head screwdrivers
-Razor Blade or Gasket Scraper
-16 gauge wires
-Wire Cutter & Stripper tool
-5/16 or 8mm & at least 4 foot long coolant hoses(x2)
-Allen Wrenches
-Hot Soapy Water
-Coolant
Before you start, make sure the engine is cold & remove the fuel filler cap to release the tank pressure:
I start out by removing the throttle cable and move it out of the way:
Remove your intake assembly out of the way; mine's a SRI so it takes me couple sec to get it out:
Then, I went and unbolt the IACV. Unbolt the two 12mm bolts:
Then I disconnected both the MAP and TP sensors off the TB:
Remove the brake booster hose off the IM:
Once thats done, I went ahead and unbolt the five plenum bolts. It's either 10 or 12mm bolts:
Lift the upper plenum off and out of the way:
It's time to unbolt the three fuel rail bolts. 10mm:
Once that's done, I lifted the injectors and rail off as one piece:
Then it's time to unbolt the IM 12mm bolts. Four up top and six on the bottom and unbolt the 12mm bolt off the IM Support Brace underneath then use the pry bar to lightly pry the IM off:
It should look like this once the IM is out, and don't forget to plug up the intake ports:
This is where the hot/warm soapy water comes in to soak up the old gasket. Some uses gasket remover stuff whichever works for you but I did my way for free. It takes alot of time and patience to get all the old gasket off and this takes the longest:
Once the mating surface is clean, install your new intake mani gasket. I used Rosko's Thermal IM gasket that came with the package:
Here is a side by side shot of the Stock VS Euro R IM:
Now, it's time to prep the IACV adapter plate. Here I used the red high temp RTV sealant for gasket between the IM & IACV adapter plate so it doesn't have any vacuum leak:
I went ahead and installed the IACV adapter plate and IACV onto the Euro R IM:
I went ahead and transfered my TB over to the new IM. Now is also the time to clean, lube, and install the injector o-rings onto your new IM:
Be sure to remove the towels you stucked inside the intake ports before you installed the IM. I made the mistake of not doing so, and realized that I didn't after I bolted the new IM on. It sucks! Good thing I caught myself though. Get your IM in and against the head:
Go ahead and install those 10 12mm bolts. Start from the center out when tightening and once that is all done, you're ready to re-install your injectors and fuel rail assembly but this time you'll need to use the allen wrenches to tighten down the rail cause of Rosko's fancy Allen Screws:
Next....
Tools Needed:
-3/8 Ratchet
-3/8 extensions
-Pry Bar
-16 gauge wires
-Allen Wrenches
-Hot Soapy Water
-Coolant
Next....
